Manual tranny differences
Old Jul 14, 2009 | 07:14 PM
2kvert's Avatar
2kvert
Default Manual tranny differences
So the Z06 and standard trannys have the same gear ratios but the Z51 is different? What's the advantage to the different gear ratios in the Z51 "performance" package? I would think it they would match to the Z06 specs but I'm sure someone else knows the answer. My 07 Z51 coupe definately doesn't pull as hard from a dig as my 01 Z06 but it is a much more refined feel.
Old Jul 14, 2009 | 08:11 PM
nwc6's Avatar
nwc6
The MZ6 is closer to the MN12 of the C5 ZO6. 1st to 4th the same and slight 5th and 6th gear difference. The C5Z weighs a lot less than the C6 Coupe. Less weight, easier to get moving. Is your 01 stock? I would think the Ls2 would be a dead even match with a 385hp C5Z. The Z51 has autocross guys in mind, where on a short course 1st and 2nd are primary used.
MZ6
2.97
2.07
1.43
1
0.71
0.57
MN12 C5 Z06
2.97
2.07
1.43
1
0.84
0.56
MN6 C5 & C6
2.66
1.78
1.3
1
0.74
0.5
Old Oct 22, 2010 | 10:59 AM
jasonberkeley's Avatar
jasonberkeley
Will a C5 MN12 bolt directly into a C6?
Old Oct 24, 2010 | 08:14 AM
jasonberkeley
ttt
Old Oct 24, 2010 | 09:07 AM
glass slipper's Avatar
glass slipper
http://forums.corvetteforum.com/c6-t...apter-kit.html
http://forums.corvetteforum.com/c6-t...post1554557645
Should answer your question.
Old Oct 24, 2010 | 10:01 AM
jasonberkeley
Ah! Thank you!
Old Oct 24, 2010 | 10:28 PM
ragtopws6's Avatar
ragtopws6
Only if the M12 is being installed on a 2005. 2006 and up have different tailshaft housing and will not work unless the tailshaft housing is replaced addition to additional modifications.
Old Oct 25, 2010 | 07:07 PM
jasonberkeley
Since my C6 is in fact a 2005, are there any modifications that would have to be made, or it literally becomes a no-brainer swap?
Thanks,
Jason
Old Oct 25, 2010 | 07:22 PM
ragtopws6's Avatar
ragtopws6
The reverse sensor connector MIGHT be different but as far as the swap is concerned, it's a no brainer swap!
To Manual tranny differences
