Brake Pads
Old Jul 23, 2009 | 09:51 PM
LKicklight's Avatar
LKicklight
Default Brake Pads
My 07' C6 Z51 still has the original brake pads and yes, they give off a lot of brake dust. Back in 05' there was a bulletin to change the pads to a set that did not give off as much dust and they were much quieter. Does anyone have any recommendations on replacement pads for my stock C6?
Lkicklight
Old Jul 23, 2009 | 10:01 PM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
If you're looking for a low dusting pad, go with ceramic. There are aftermarket pads and Gene Culley on the Forum here can get you GM ceramic for about $150. per "axle" (front/back)
Old Jul 24, 2009 | 12:30 AM
jsbwac's Avatar
jsbwac
I just installed Hawk ceramic pads and they have been great both with stopping and producing almost no dust.
Old Jul 24, 2009 | 07:05 AM
ShinodaVette's Avatar
ShinodaVette
I went with GM ceramic pads on my '06 and I'm very happy with them.
www.partstaxi.com, a supporting vendor here on the forum sells them for a reasonable price and has good customer service:
GM Part # 88909667 for Fronts
GM Part # 88909668 for Rears
Old Jul 24, 2009 | 09:17 AM
dlive's Avatar
dlive
6th Gear
I went with the GM pads about 2300 miles ago and they hve performed great, no noise and little dust.
Old Jul 24, 2009 | 09:49 AM
User 81424's Avatar
User 81424
Old Jul 24, 2009 | 09:00 PM
sea six's Avatar
sea six
Old Jul 24, 2009 | 09:22 PM
JJC5's Avatar
JJC5
Delco ceramics from Gene.. Same as above, no noise and very little dust
Old Jul 24, 2009 | 11:12 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've received my ceramics from Gene already when I happened to notice that the rotors are worn down badly. Not scored or metal to metal things.. just worn badly that the outer edge area where the pad doesn't contact, is much higher...not a little. I ordered rotors from Gene yesterday.
Old Jul 25, 2009 | 11:11 AM
jimmie jam's Avatar
jimmie jam
did mine last year. NO dust!
Old Jul 26, 2009 | 07:27 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Old Jul 27, 2009 | 11:30 AM
PartsTaxi.com's Avatar
0PartsTaxi.com
Former Vendor
Thanks for the referals!!!! I do have those pads in stock if anyone else needs them.
Kevin
www.PartsTaxi.com
Old Jul 27, 2009 | 11:46 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Lkicklight
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
7% off for forum members
F: CT731 $137
R: CT732 $118
To Brake Pads
