What to do with 2k
This would be a good solid starting point. You'd have to get past the fact that you'll be running headers manufactured in "***** Khu, China"
or somewhere like that. Feedback on the forum has indicated that the build quality is "pretty good" on these pirated copies of U.S. designed headers.AR's or Kook's headers. 160 stat is nice. Install everything yourself!
The only thing keeping me from a converter is the rear is ?? (I have 3.15 gears stock) but I would need a Trans cooler also.. as for headers I'm on the fence, as I had headers on my 96 and muffler eliminators, and the "DRONE" was unbearable..
I also have ridden in C6 with aftermarket exhaust systems & they also were too loud if I'm taking a long trip (3 hr or more)
Sure loud exhaust sounds nice and is fun if your only going to the car show a 20 min ride... but if you plan on going several hundred miles with the wife, the drone can be a PIA..
I WILL NOT go to any after market exhaust, but might just go with headers, & my stock mufflers... & a 2800 converter and hope I don't need a trans cooler also...
I'm guessing if I go with a 3200 converter "ONLY" I should be a high 11 sec car in "Good Air"
I had a cooler on my 96 with the 3600 converter, & NEVER had a problem with the trans temp!! I think if i do go with the converter I WILL go with the cooler at the same time.. ...better safe than sorry!
