I only use Bosch 4+ platinum plugs. Always use anti sieze, the problem is some people goop it on, just a small amount to cover the threads and it will save you a broken plug later on.
I have driven LS1's for the last 10 years. I have heard for a long time now that NGK's have a special coating on them and don't require anti seize. Read about it here: http://www.ngkplugpro.ca/content/con...SparkPlugs.pdf
With other brands of plugs, I would use a little anti seize. I have used NGK's with no anti seize without any problems.
Let me see GM dose not use anti seize for the first 100,000 mi. so
why should I need it for the next 100,000 mi. I'm on my third vette
and have never used anti seize on plugs.
I'm an automotive instructor and I've never heard of any problem from using antiseize on plugs that do not have a "special antiseize coating". AND it appears that the only problem is really over torquing due to extra lubricity (special coating plus antiseize). Now, IF the correct plug is used and antiseize is used with no special coating I don't see any possibility of ANY problem. There are factors other than heat range related to a plug that could cause electrical interference. I say if you have dissimilar metals (head and plug) and no special coating on the plug, you BETTER use an antiseize.
Almost all modern engines use aluminum heads. Do you have a list of spark plugs manufactured today for aluminum heads (Corvette) that DON'T use plating and/or protective coatings and rolled threads?
BTW, the problem with anti-seize and over torquing is not related to the presence of plating or dry films PLUS anti-seize. It is caused by the anti-seize.
"Champion recommends that you do not use an anti-seize compound, since one has already been applied to the plugs at the factory. Next, install the spark plugs finger tight and, it using a taper seat spark plug, use a ratchet to rotate 1/16 of a turn. If using a gasket seat type spark plug, after installing finger tight, turn 1/4 to 5/8 of a turn. If this procedure is followed, spark plugs will not back out nor will they seize in the cylinder head."
"NGK specifically states do not use anti-seize."
"Autolite -We do not recommend the use of any anti seize products for installing spark plugs. Anti seize compounds have a torque multiplying effect when installing plugs. This can lead to thread distortion and thread galling resulting in cylinder head damage. Autolite spark plugs are nickel plated to resist the effects of corrosion and seizing.
Anti-seize on the threads of your spark plugs will slow down the rate of heat transfer from the plug to the head. The worst place to use it is on the tapered seat, which is where the most heat transfer occurs between the spark plug and the cylinder head. Even just a small amount of anti-seize is the equivalent of using a hotter heat range spark plug."
"AC Delco - Do not use any type of anti-seize compound on spark plug threads. This will decrease the amount of friction between the threads. The result of the lowered friction is that when the spark plug is torqued to the proper specification, the spark plug is turned too far into the cylinder head. This increases the likelihood of pulling or stripping the threads in the cylinder head. Over-tightening of a spark plug can cause stretching of the spark plug shell and could allow blowby to pass through the gasket seal between the shell and insulator. Over-tightening also results in extremely difficult removal."
Really? Everything I've seen and read says the stock wires are excellent, just as good if not better.
that's funny there's 6 posts here pointing to the MSD's. I put RR's in and removed the plugs a couple of times to adjust the valves. I developed a misfire and thought I had done something wrong with the set up/ lash, I checked everything including the continuity of the wires all seemed fine. as a last resort I changed wires, THE CAR HAS NEVER IDLED/RUN THIS GOOD SINCE I BOUGHT IT! 30 years as a mechanic/millwright, and I have never had a bad plug wire including those sets you put together yourself!
well i wish to thank everyone for their input. it turned out that the use of anti seize was a bigger issue on this thread than the plugs themselves.
anyway here is what i decided to do after reading comments from all and speaking with the manufacturer.
i am going with a set of plugs from NGK and using their TR5 IX. they said the only difference between the TR5 and the TR55 was the gap.
TR55 come pre set at .060 and TR5 come pre set at .040. according to chevy .040 is the proper gap hense the decision to go with the TR5. also decided to go with the "IX" version which is their Iridium plug. NGK also states not to use anti seize compound. they claim their plug is designed to work with aluminum heads and is made or coated (can't remember which) of a different metal to ensure the plugs do not stick.
i already have upgraded wires so this should do it.
Be careful because some spark plugs will cause a service charging system error that will last for months and months and drive you completely insane!!! I would recommend getting new stock plugs.
Be sure to check the gap on those new plugs and be careful as the tips are fragile in regards to the typical gap tool, don't pry on the tip if they are a little under the .040 gap you desire..
Thanks for all the good info here. I will be installing a new set of AC plugs and wires in the next couple of weeks and will not use the anti-seize compound on the threads.
My tuner recommends the NGK TR6 plug gapped at .038. This is one step colder than the TR5 plug and he has had great success both in street and track use applications.
