07 clunk when full turn?
Old Aug 23, 2009 | 09:39 AM
Strick's Avatar
Strick
Default 07 clunk when full turn?
Is this a common thing with the C6? It seems my son's 07 C6 vert with runflatsmakes a clunk sound when he goes to a full turn. Normal?
Old Aug 23, 2009 | 09:55 AM
torquetube's Avatar
torquetube
I'm going to say yes. There are actually several clunk noises that can happen at full lock (you'll have to be more specific) but they're all pretty common.
Old Aug 23, 2009 | 11:34 AM
SgtRod's Avatar
SgtRod
Just for shiz and giggles check your exhaust maybe its loose and clunks under G force.
Old Aug 23, 2009 | 01:04 PM
Leprkon's Avatar
Leprkon
might also be a cracked end link on the sway bar. stock links are one of the two or three top warranty items.
Old Aug 24, 2009 | 03:25 AM
MarkRx's Avatar
MarkRx
rear diff clunk? sounds like a muffled fork in a garbage disposal.
Old Aug 24, 2009 | 06:18 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default Yes
My 2005 made a clunking sound when I made slow, very sharp turns. I beleive there is something the dealership can fix. You may want to bring it in and have it checked out.
Old Aug 24, 2009 | 08:58 AM
Strick's Avatar
Strick
Thanks guys. It doesn't seem like something that should be normal in such a wonderful car. I, too, think a trip to a good dealership or good front end shop is in order for a detailed inspection.
Old Aug 24, 2009 | 12:57 PM
quickc6's Avatar
quickc6
You maybe able to get 4500$ in cash for clunker . Sorry couldn't help my self .
Old Aug 25, 2009 | 07:20 AM
Strick's Avatar
Strick
You must be a Rustang owner.
Old Aug 25, 2009 | 10:40 AM
quickc6's Avatar
quickc6
NO Fords here
Old Aug 25, 2009 | 11:27 AM
drivinfast's Avatar
drivinfast
I know guys that have replaced sway bar end links several times
Old Aug 26, 2009 | 11:03 AM
hot1's Avatar
hot1
Check end links, first
Old Aug 27, 2009 | 05:51 PM
SnapperDragon's Avatar
SnapperDragon
NO Fords here
Ford has good cars, don't knock them. My 06 Focus is at 54K miles with no maintenance costs other than consumables (oil changes and one set of tires, no brakes or anything else yet).
Old Aug 27, 2009 | 05:55 PM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
My 05 did just the same thing. It sounded like it was coming from the front on left hand turns when actually it was the rear-end clunking. Change it with Dexron LS or Mobile 1 75-90 fluid, do eight figure eights to let it work in the clutches and you should be good to go. There is a very good sight on this forum explaining the procedure but I have to go now therefore you will have to try to find it yourself. It is probably what is making the noise...if not try the end links too. Good luck and keep us posted.
Old Aug 28, 2009 | 08:56 AM
Bandit1's Avatar
Bandit1
To 07 clunk when full turn?
