Aerodynamics question
Old Aug 26, 2009 | 10:16 AM
bmatthe2's Avatar
bmatthe2
Default Aerodynamics question
I'm not sure if this is in my head or a reality but I recently lowered the rear end of my C6 on stock bolts so its only about half an inch lower than stock. I did not touch the front. At high speed the front end feels a bit ligthter than it did before. Am I crazy or is this happening? Should I lower the front to even it out? Or is this just in my head because lowering half an inch in the rear shouldn't make any real difference.
Old Aug 26, 2009 | 10:30 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
How fast are you talking? Yes, this can really make a difference. I'm no expert on the aerodynamics of the C6, but there is a proper front to rear rake.
Old Aug 26, 2009 | 10:32 AM
bmatthe2's Avatar
bmatthe2
It seems to feel lighter 100 and above.
Old Aug 26, 2009 | 10:46 AM
dennis50nj's Avatar
dennis50nj
get a 4 wheel alignment to the new height
Old Aug 26, 2009 | 10:58 AM
Eric D's Avatar
Eric D
Check this posting on how to set Z - Height.
Old Aug 26, 2009 | 11:07 AM
Walt White Coupe's Avatar
Walt White Coupe
There is no question that decreasing the rake angle of car will decrease aerodynamic down force. But I would doubt that you could feel the difference.
Old Aug 26, 2009 | 11:08 AM
quickc6's Avatar
quickc6
You are losing downforce because you changed the rake on the car .
Old Aug 26, 2009 | 11:11 AM
dennis50nj's Avatar
dennis50nj
that's great info if he was keeping the stock factory set height, but he lowered it, so he has to go to a shop that can align to the new height without raising it to the factory height. i assume he wants to keep it lowered
Old Aug 26, 2009 | 11:16 AM
dennis50nj's Avatar
dennis50nj
the rake wouldn't come into play at a 100mph, i had the same problem when lowered, even at lower speeds, got the alignment and its fine now, have been 165 straight as an arrow with skinnies and drag radials
Old Aug 26, 2009 | 11:32 AM
bmatthe2's Avatar
bmatthe2
I had an alignment done after it was lowered and it drives straight just feels a little less stable. Also it seems to be a little lower on the driver side could this be the problem?
Old Aug 26, 2009 | 11:37 AM
dennis50nj's Avatar
dennis50nj
yes as it should be higher on the drivers side so when you get in its even, my car is way low in the back, plus a shorter tire in the back, it feels no float, also every shop cant align
Old Aug 26, 2009 | 12:19 PM
CMY SIX's Avatar
CMY SIX
you and walt white must be smoking something, by dropping the rear he's pointed the nose up like the edge of a wing and is lifting the nose, the other guy talking about "wedge" is right these are not "lowering bolts" as alot of you engineers like to call them, they are "wedge bolts" just like in NASCAR and the Corvette is one of the few street cars that have them, they are for setting the front to rear "wedge" I love going for sprited drive's with the" lowering bolt cars" I always wonder why they all ways end up on the back of the group?
Old Aug 26, 2009 | 03:34 PM
snow's Avatar
snow
St. Jude Donor '10, '17-'18-'19
so are you saying that the lowering bolts that you see for sale out there should not be used? is there a correct way to lower a C6? My old 350Z I did Coil overs and was able to adjust the hight... just wondering
Old Aug 26, 2009 | 03:55 PM
ChopShop1's Avatar
ChopShop1
Old Aug 26, 2009 | 04:20 PM
Amric's Avatar
Amric
I you wanted to be 100% sure to maintain the factory balance while lowering, you would need 4 scales to measure before and after corner weight bias. You would still be left with a different static spring rate, but that is less of an issue.
Old Aug 26, 2009 | 06:42 PM
LEAVINU's Avatar
LEAVINU
To maintain the rake you should lower the front as well. Any reason why you would lower the rear and not the front? Based on what you posted it sounds like the car is level at park most likely.
But when on the gas the rear is going to squat making the front higher than the back now. If you lower the front too, once on the gas it will still squat the back BUT it will create a close to level height vs the front being higher. I lowered mine all around and cut the bushings. I still have rake from front to back.
Old Aug 26, 2009 | 07:45 PM
Wayne O's Avatar
Wayne O
CF Senior Member
There is a factory spec rake but most serious Corvette racers I know essentially level their car for track use eliminating the factory spec rake. Just turning the so-called 'lowering bolts' an equal number of turns is no guaranty your car will be setup properly. Actually, the setup may be off right from the factory (you don't know unless you check it first). Anytime you turn one of the 'lowering bolts' it affects the other corners of the car (the one diagonally the most). To some extent you can adjust the setup using the 'lowering bolts' but specific procedures should be followed, measurements taken, etc.
To Aerodynamics question
Old Aug 26, 2009 | 07:53 PM
MitchAlsup's Avatar
MitchAlsup
1: you have pointed the nose up. This can cause the nose to become light at speed as air packs under it. It also alters the flow of air under the car and at the back of the car at speed.
2: you have decreased the rear roll center. This alter how much weight is transfered to the front and back tires in corners.
Old Aug 27, 2009 | 01:41 AM
xcessivex's Avatar
xcessivex
Personally I can't see myself modifying a car and and jerry rigging it. Put some pfadt coil-overs on the car and do it right. If it still feels light its because you are going 190mph and dont have a some cannards and a rear wing...
...yea, I said it... a wing.
But seriously the pfadts are worth every penny, it's night an day... and yes you may feel a little light past 190 and yes you may need a wing if you intend on sustaining and passing that speed while changing lanes vs bikes on the highway... If you got the vette for any other reason... return it and stick to the right lane... I hear Kia is making some nifty cars
Old Aug 27, 2009 | 09:41 AM
Eric D's Avatar
Eric D
What type of track use are you talking for “serious Corvette racers”. One of the unique features of the Corvette is how easily (comparatively speaking) the suspension can be changed. I can see the need to tailor the adjustments for the type of track use one plans to use with the car. For example, drag race cars would most likely want to reduce the aerodynamic loads as much as possible, and I could see reducing rake and going to a more level profile might be the better choice.
Auto-x and road racing at a lower speed track might also benefit from leveling. But I believe that any high speed track with turns the car would benefit with maintaining rake to add down force. I guess my thought is this would allow for higher speeds in and out of turns.
A car used as a daily driver it probably doesn’t matter much and the factory setting might be the best all around choice.
If you are a speed demon and not really racing anyone but your personal ego then maintaining or adding more rake might be the better choice to keep the vehicle more stable, in that the added drag doesn’t matter. This might be the better choice for the original poster.
