A/C Vent Technical Question
Old Aug 27, 2009 | 05:16 PM
shockwaveharry's Avatar
shockwaveharry
Default A/C Vent Technical Question
Complaint: I can get full flow through the dash vents or floor vents but when I select the bi-level setting I only get flow through the floor vents.
Without having ever looked at a service manual or having any idea how the A/C vents are controlled in a C6, I'm wondering if there is a normalizing procedure that can be performed to the blend door system.
I have late model Mercedes experience and it's not uncommon to have to normalize the stepper motors when we have a temperature or flow complaint. The stepper's full open/full close values can change from the actual vent position over time and require this.
I don't have access to a Tech II so I'm wondering, if there is a procedure, can it be done without it?
Last edited by shockwaveharry; Aug 27, 2009 at 10:56 PM. Reason: corrected wrong information
Old Aug 27, 2009 | 09:30 PM
CMY SIX's Avatar
CMY SIX
did you feel under the dash? way under
Old Aug 27, 2009 | 10:58 PM
shockwaveharry
Actually, I mis-stated my complaint. In bi-level mode, I only have air discharging through the floor vents, nothing from the dash face vents.
Old Sep 5, 2009 | 04:01 PM
shockwaveharry
Any tech's out there than can help?
Old Sep 5, 2009 | 06:44 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
If you unhook your battery for several minutes, the motors will re-calibrate when you re-connect.
Old Sep 8, 2009 | 04:37 PM
shockwaveharry
Ah... Muchos Gracias! I'll give it a try.
Old Sep 8, 2009 | 05:28 PM
calemasters's Avatar
calemasters
Try doing a reset of the HVAC contol head by turning on ignition and press and hold these 3 buttons simultaneously for 10 seconds:
Front Defrost
Rear Defog
Fan Up
Old Sep 8, 2009 | 05:47 PM
'VETTE PHASE
Front Defrost
Rear Defog
Fan Up
I knew there was something like this, but I couldn't remember which buttons to push and the computer I was on at the time didn't have my SI on it to look it up.
Don't forget to re-index the windows.
To A/C Vent Technical Question
