Throttle blip
Old Sep 11, 2009 | 11:47 AM
Slogo's Avatar
Slogo
Default RPM Delay
I just got done with the muffler mod 3/4 " hole through inner pipe inside muffler , sounds good. I notice that when I shift between gears, the RPM will fall back down ( as it should)and then momentarilly blip up a few hundred rpm and then fall back down again. Is this normal or am I noticing it more because of the slightly louder pipes? PS; When at idle and I hit the throttle, (in neutral ) time seems to lag before the engine revs up, like a delay. . Could the muffler mod have changed anything. Thanks for advice.( 6 sp manual, 14 K miles)
Old Sep 11, 2009 | 03:31 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Sounds like a vacuum leak... Does it hunt at idle too? Did you mess with the engine recently?
