Yet another broken clutch spring recipient!
Old Sep 17, 2009 | 05:50 PM
Jim Nebraska's Avatar
Jim Nebraska
Default Yet another broken clutch spring recipient!
Hi....I'm looking for some advice from you Forum chums who have suffered the oft reported "broken clutch spring". Mine broke...about 2/3 is still inserted in the clutch area, so I still have functionality. I ordered a replacement and have it in hand. I can clearly see the two mounting holes and where the bracket and bar couples the clutch to the spring.
Here's my concern....on the Forum thread I found, several members said removing the spring was a piece of cake, but reinstalling the new spring was really tough...if not impossible. I don't want to get stuck halfway....have any of you been able to reinstall a new spring? Are there any tricks?
Thanks as always.
Jim
Old Sep 17, 2009 | 05:52 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Mine broke so I took it to the dealer and they replaced it for free... Only thing I've ever had to take the car to the dealership for...
Old Sep 17, 2009 | 06:06 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
any pics of the spring?
Old Sep 18, 2009 | 01:54 AM
kharyespy's Avatar
kharyespy
Default Clutch Spring
Mine broke and I've been running the car with out it for about 2-3 months....seems to be working fine without it and the clutch feel seems to be a bit better. Hopefully I am not ruining anything by doing so. Thoughts anyone?
Old Sep 18, 2009 | 02:57 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Running without the clutch pedal return assist spring or using one with improper torsion could lead to premature clutch failure...use the proper spring. I was going to post a link to a thread explaining why using no spring or the wrong one was a bad idea but I just checked and the page is gone...odd?
Here's a link that may help you reinstall the spring. IMO it was a very easy fix. Before you remove the remaining part of the broken spring, put a pad down and slide-in on your back and look carefully to see exactly where the replacement spring is going to go. Again, it's really easy to do...hopefully the following link will help. Good luck!
http://forums.corvetteforum.com/c6-t...ing-in-c6.html
Old Sep 18, 2009 | 09:50 AM
Jim Nebraska
Thanks....I'll give this a try. I've done the body contortion necessary to see the spring.....were you able to use both hands?
Old Sep 18, 2009 | 12:01 PM
Chuck A's Avatar
Chuck A
I will need to check this out, when i can, but if there isnt a spring how come my clutch, pops up, and then when i press it down, theres is friction, i am still learning
Old Sep 19, 2009 | 08:00 PM
Revving High's Avatar
Revving High
dealer replaced mine
To Yet another broken clutch spring recipient!
