Old Mar 2, 2015, 08:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Throttle position sensor?
Old Nov 25, 2009 | 07:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I ported my own LS2 TB and I have ZERO codes
Stock un-ported on the LEFT, and home port on the RIGHT:
Its tough to get a good picture of the port job. The shiney finish makes an optical illusion
Ported TB mounted.
Bill
Old Nov 26, 2009 | 12:02 PM
Sinister Evil's Avatar
Sinister Evil
how much is a gas pedal assembly and where can I get the whole set of parts I need to replace...seems like the cheaper option....and if it is the throttle body then I guess I'll buy a new ported one.
Old Nov 30, 2009 | 01:50 PM
InMyRearView's Avatar
InMyRearView
How much is a new ported one? or just a stock one? any ideas? my car is in the shop now.
Old Nov 30, 2009 | 08:14 PM
drivinfast's Avatar
drivinfast
my issue turned out to be the brown TB wire at the ECU was shorting and would make the reduced engine power mode come on. tuner ran a new wire and its been fine since.
Old Nov 30, 2009 | 09:59 PM
InMyRearView
what codes did your car throw? i want to make sure i dont replace an entire TB if it isnt needed. these are the codes my car threw at me
P2135ATPS 1-2 Correlation
P2176A Min throttle position not learned
Any ideas what those could lead to?
Old Nov 30, 2009 | 10:15 PM
drivinfast's Avatar
drivinfast
I'll email Taylor, and post answer or PM me
Old Aug 4, 2015 | 07:16 PM
YellowSpade's Avatar
YellowSpade
Cruising
Just to bring resolution to this thread:
TPS sensor issue can be caused by buildup of gunk in the throttle body.
30min project, wipe it down slap it in and there's a good chance your car'll drive like new again.
YellowSpade
Old Apr 10, 2018 | 03:15 PM
87 Morgan's Avatar
87 Morgan
3rd Gear
YellowSpade
I have been throwing the P2135 code intermittently for awhile and the P2119 came yesterday. Either way, I removed the TB cleaned it and put it back in and drove around the block. Cars run fine and no CEL' s on in the dash. I would be ecstatic if the solves the problem in lieu of a $330 or Throttle body.
Old May 25, 2019 | 01:32 PM
rdefee's Avatar
rdefee
3rd Gear
Default How to purchase 12570790
Originally Posted by RichieRichZ06
TPS is not available seperately. All LS2, LS3 and LS7 use the same TB. Part number is 12570790 and my forum price is $327 (retail is $545) Shipping is cheap from me as well.
RICH
Need to know how to purchase. Keep getting p0222 error message.
Old May 25, 2019 | 04:26 PM
double06's Avatar
double06
Inspect your TB connector the 6 pin plug. The low voltage wire I think throws the 222 code do look at schematics to see which one it is. They can wear out get loose over time depending on the situation. ALso make sure it is snug on there. They have a locking clip.
Old May 27, 2019 | 10:55 AM
WI Badger in OBX's Avatar
WI Badger in OBX
i am experiencing the same problem in my 05..worst case scenario is i will replace it. anybody have any idea how much a TPS is? thanks.
I had to replace mine and the sensor is built into the throttle body had to replace the full throttle body I got a friend to hook me up I paid about $200 to do the replacement.
