C6 Best tire size
C6 Best tire size
What are the best size tires for the rear of a C6? Is it the stock 285/35/19 or more like the Z06 size? Please advise...
It is difficult to fit the Z06 325/30-19 rear without cutting the inner tubs or using offset wheels. You can fit a 305/30-19 (I used Michelin PS2) on the stock rear wheels. The 305 is slightly outside the recommended wheel width for an OEM wheel, but I have done it and it works and fits well inside the stock fenders. A very clean way to do this is to send your wheels to WeldCraft and have them add 1" to the inside of your rear wheels. Everything will fit inside the fenders perfect.
You can also add the 275/35-18 tire to the stock front wheels and it will fit inside the front fenders very nicely.
There's a chap selling CCW's in the C6 Parts for Sale Section that claims that they will fit Z06 sized tires on a C6 with no problems.
I can tell you from experience that Michelin 275/35-18 tires mounted on OEM C6 wheels do not rub on the front. I even had the wheels widened 1/2" on the inside and they do not rub. My car was only lowered slightly.
Also, 305/30-19 mounted on the rear do not rub as well as 305/30-19 mounted on a 1" widened rear do not rub, but they are very close. You can fit a 315 tire on the OEM rear, but Michelin only made it in the Pilot Sport Cup and they are hard to find.
CF Senior Member
You asked for the best tire size and IMO that's the best way to go for street driving. On the street I use CCW SP16A wheels, 9.5” x 18” front - 11” x 19” rear with the Goodyear Eagle F1 Supercar EMT’s...275/35ZR18 front - 325/30ZR19 rear...stock Z06 tires.
"best" means different things to different people...what's the goal?
in some ways, the best is what's already on there...it's paid for and works...if there's something you want the car to do better, what is it?
I'm switching to 315/30's next season because I think the shorter tire will be better
a 325 Invo should mount on an 11 easily
Nitto says they'll fit on the 11" rim, although 11.5 is the recommended size. I'm just wondering if they clear the sheetmetal when you go over a bump. Nitto describes the 12.91" as "overall width" so I assume that is more than tread width??
Here is my link.
http://forums.corvetteforum.com/c6-p...-seperate.html
I will add some additional pics so you can see them on the car. They tuck under Perfectly. Its what they should have came up with stock
IMHO.
Thanks for looking
that is probably section width...yes, wider than tread width
