Vararam Help
Old Oct 16, 2009 | 06:34 AM
Griffee's Avatar
Griffee
like i said before Vararam is king, you cant blame it if you cant install it right
Really? You honestly typed that out with sincerity? For real?
Funny guy you are!!!!!!
The Vajunk is KING, for the opportunity of dirt ingestion in your motor! Nothing else poses as great a risk.
Old Oct 16, 2009 | 10:41 AM
dennis50nj's Avatar
dennis50nj
obviously not as mechanically inclined as you think you are
Old Oct 16, 2009 | 10:49 AM
dennis50nj's Avatar
dennis50nj
Originally Posted by LS1LT1
what appears to be a gap or a leak is just some minor bowing and the filter is still perfectly sealed. If you take the unit out in one piece (relatively simple procedure) and inspect the areas both before and after the filter then you can tell.
Old Oct 16, 2009 | 11:21 AM
jpee's Avatar
jpee
Just as an update... my intake was buckled a little, I called Vararam, & spoke to Steve.. he said "No Problem' & they would send me the newer version with the new tape to seal it...
I'll for sure let you guys know how it fits and works... my old one was NOT a piece of junk!! I think it was not "stiff enough" that problem should be taken care of with the new one...
Thank you Steve & Vararam..
04_Z06_CE's Avatar
04_Z06_CE
LOL..Same ole people whoring the Vajunk...
Old Oct 16, 2009 | 01:01 PM
c6 batmobile's Avatar
c6 batmobile
Old Oct 16, 2009 | 03:57 PM
dennis50nj's Avatar
dennis50nj
same old basher, funny thing you have never had a vararam for a c6, i have, 3 of them as a mater of fact, i have had no problems, so tell us about your personal problems with the vararam, so we can figure out whats wrong
Old Oct 16, 2009 | 04:38 PM
LS1LT1's Avatar
LS1LT1
And once again, same ol' people pointing out that it's the same ol' people whoring.
It goes both ways bud.
Old Oct 16, 2009 | 05:39 PM
c6 batmobile
I did. nobody has a clear answer that says why my intake doest fit correctly. Its up for sale right now.
Old Oct 16, 2009 | 06:18 PM
jpee's Avatar
jpee
I also have an 05...if the person who did the install don't do it correctly ..yes you will have problems....
& YES mine did have a small bend on the plastic where the upper & lower connect.. however they "VARARAM" said I will have a NEW STIFFER part in a week...
I have no reason to not believe them...Yes its more work to clean the filter than to clean a stock air filter... but that goes with almost all mods...
For any part you buy to GAIN performance you have to "Give" up something... Nothing is FREE!
Old Oct 16, 2009 | 06:27 PM
dennis50nj's Avatar
dennis50nj
is it warped , does it have top bottom and side seals did you put it in and out as a unit and is the front tabs hooked in the grill as this hanging contributes to warpingand what doesn't fit correctly
Old Oct 16, 2009 | 06:56 PM
GetSum's Avatar
GetSum
Default Vararam Proof is in the pudding!
Well I dont want to argue with anyone but if you look at the guys on the fast list, the ones at the top especially the boltons list which is the best comparison because 99% of the parts are the same (Cam Heads etc) The fastest guys all have Vararam! Thats all the proof I need!!!
Old Oct 16, 2009 | 07:17 PM
  #33
c6 batmobile
It has all the seals top bottom and side. I epoxyed them as well. I installed the unit as a whole making sure the holes were lined up and nothing was hanging. I have the new top so warping is not my issue but the top and bottom dont mate together. I check on it almost everytime I drive the car because I open the hood afterwards to let the heat out and about 99% of the time it has lost its seal again. Even after epoxying the seals in I checked it and so much dirt had rammed its way in between the seal and the unit that they just fell out AGAIN. I want to reinstall another set of seals but at the same time what is the point if they are just gonna freaking fall out again.
Old Oct 16, 2009 | 07:21 PM
  #34
Griffee's Avatar
Griffee
And the list of engine dirt eaters is every bit as long and more. All the proof I need!!!!!!! Vajunk!
Old Oct 16, 2009 | 07:29 PM
  #35
brian90505's Avatar
brian90505
Vararam threads are always entertaining.
Old Oct 16, 2009 | 07:47 PM
  #36
GetSum's Avatar
GetSum
Like I said Im not here to argue, I provided proof. What did you provide?
You never had a Vararam did you? What mods do you have? Id love to know. Id like you to post a time slip too Just so we know where you stand
Old Oct 16, 2009 | 07:56 PM
  #37
c6 batmobile
read the vararam is a piece of junk thread. I started it and there are countless replies of people that have had problems. Ive had both versions the old and the new and "improved" and they have both had sealing problems. I know that the intake produces results but the risk of injesting who knows what is very high. Im not trying to argue the effectivness of the unit at producing power but the quality is extremely poor and the risk for engine damage is very high. If that is a trade off your willing to take then the vararam is the right piece of equipment for you. Im personally done with mine. Im getting rid of it. I even put in my sale thread that they have sealing issues and people still want it. Im just amazed.
To Vararam Help
Old Oct 16, 2009 | 08:06 PM
  #38
Griffee's Avatar
Griffee
So many comedian's in this thread I had to check my url to make sure it didn't say comic relief!
Did you really ask that? Okay let me focus....yep..yep you did....hysterical.
Maybe try reading the link I provided. Maybe try getting all "your facts", and "proof" in order. Maybe try doing a search as well and look at the countless pictures of Vajunks since there are so many threads on them.
Old Oct 16, 2009 | 08:22 PM
  #39
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I didn't read if you have owned one or not Griffee?
c6 batmobile, it seems like you are not connected up in the front possibly from your description.
As Dennis mentioned, the front of the unit has to be resting on the top of the two tabs under the front grill.
My Vararam is very solid when put together in or out of the car.
c6 batmobile
PM me if you want to, I would be happy to call you and compare notes with you if you would like.
Old Oct 16, 2009 | 08:28 PM
  #40
Griffee's Avatar
Griffee
Yes, sure did...sold it for $25. The fellow that bought it was kind enough to tip me and bring the sale up to $40.
