rear diffuser question !!!
Old Oct 23, 2009 | 09:50 PM
LS3_08's Avatar
LS3_08
Default rear diffuser question !!!
Hi guys, i want to ask you about the rear diffuser for the c6 << when i pass 270 km in my c6 the car keeps going left and right (no stability) because of the turbulence under the car , i found a diffuser but i duno if this would work , here is the link : http://www.mamotorworks.com/corvette...-166-9048.html
i found also a replacment for my rear fasica with diffuser but the cost is so high for a part like this (costs 1,500 $), here is the link : http://www.breathlessperformance.com...arDiffuser.asp
your help is appreciated
Old Oct 23, 2009 | 10:23 PM
OhNiner's Avatar
OhNiner
Have you altered your ride height?
Old Oct 23, 2009 | 10:34 PM
drivinfast's Avatar
drivinfast
At 167-170 mph the C6 vette is stable. at least mine stock was. higher than that I cant say cause I upgraded stuff after that.
there could be a cross wind.
as previous poster asked if you adjusted the ride height and did not leave the "rake" that could affect things
you could need an alignment
what about tires. do they have more than 20,000 miles on them 32,000 kilometers?
rather than a diffuser I would suggest either Bilstein or Koni shocks and an upgrade to the sway bars.
Old Oct 24, 2009 | 11:16 AM
LS3_08's Avatar
LS3_08
any other suggestion??? my car is moded, when it was stock i didnt face this problem
Old Oct 24, 2009 | 11:32 AM
c6 batmobile's Avatar
c6 batmobile
What kind of mods?
Old Oct 24, 2009 | 11:53 AM
LS3_08's Avatar
LS3_08
Originally Posted by c6 batmobile
What kind of mods?
headers, cat-back, CAI, Cam, hp tune,
Old Oct 24, 2009 | 02:01 PM
OhNiner's Avatar
OhNiner
Then nothing has changed that would affect the handling unless you now have a problem with your car. Maybe your tires are not properly inflated, you have a damged tire or wheel or maybe your alignment got messed up.
Old Oct 25, 2009 | 04:09 AM
LS3_08's Avatar
LS3_08
there is nothing with the car, i have 2 of my friends ( one own a cammed zo6 and the other strocked ls2) both of them having the same problem, many guys adviced to go with the diffuser as it do lower the turbluence under the car
Old Oct 25, 2009 | 02:35 PM
OhNiner's Avatar
OhNiner
The mods you did would have no affect on the handling at any speed you were traveling at before unless you are getting tire spin at the high speed which I doubt. If you want higher track speeds and you play with the aerodynamics of the car make sure you look at the whole package, not just a rear diffuser. You might want to add a front splitter and side skirts plus a full on race wing for the back.
Old Oct 25, 2009 | 03:20 PM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
Mine's stable at 170. Lowered on stock bolts, Bilsteins, Pfadt bushings with Z51 sways.
Check your alignment, axle nuts, all steering componentry, and very carefully inspect your tires. You may have a slight delamination developing.
There should be no need for a wing at 170 on the C6. It just adds drag, and will likely build heat in your tires.
Old Oct 25, 2009 | 07:41 PM
Xedes's Avatar
Xedes
Someone does have a used breathless diffuser for sale in the, well, in the "FOR SALE" section.
Old Oct 29, 2009 | 12:28 PM
mjorgensen's Avatar
mjorgensen
For a diffuser to really work the rest of the belly pan has to promote the air flow to it. The bottom cannot be totally smooth as the air will pull away from it and cause lift also. There needs to be tumbling surfaces that help the air stream re attach over and over so it makes it to the diffuser. Those add on blades will do nothing, you would need a complete package to be worth your time.
I also agree with those above that question your alignment and or rake front to rear as a possible solution.
To rear diffuser question !!!
