New PB!!!!
Old Nov 10, 2009 | 09:39 AM
Isaiah48's Avatar
Isaiah48
Great Time! You keep stretching your lead farther and farther...
I'm coming for you though...
Old Nov 10, 2009 | 11:02 AM
Isaiah48's Avatar
Isaiah48
Hey Andrew, I just noticed your from Lewisville, TX... I went to Lewisville HS as my home HS school and Grapevine HS for Auto Mechanics back in 1982...
Old Nov 10, 2009 | 11:35 AM
dsp300c's Avatar
dsp300c
small world. I have been here for about 8 years. I moved up from Waco.
Old Nov 10, 2009 | 11:39 AM
Isaiah48's Avatar
Isaiah48
Is "The Colony" still growing?
Old Nov 10, 2009 | 11:43 AM
dsp300c's Avatar
dsp300c
Yea. Everything is blowing u here. It is crazy compared to what it was like when I moved here 8 years ago.
Old Nov 10, 2009 | 12:01 PM
Isaiah48's Avatar
Isaiah48
I'm anxious to here what clutch suggestions you get, I had to take out my Zoom dual disk temporarily until I get some resolution on it. Depending on whether they warranty it will decide if I'm staying with it or looking for something else. The Zoom Dual Disk definitley wouldn't meet your criteria though, it held good but it was a leg breaker and was fairly on/off in nature...
I put my stock one back in so we'll see how if it lasts long enough to get me through the season, shouldn't be too much of a problem since we really only have about a month left here. All I did was a quick dress of the pressure plate and flywheel to clean of some hot spots and through it back in.
Old Nov 10, 2009 | 12:06 PM
dsp300c's Avatar
dsp300c
Taking car in soon. Since my clutch fluid doesn't get dirty they are thinking I might have an air pocket in my clutch lines. So they will try and bleed it first.
Old Nov 10, 2009 | 06:19 PM
PRE-Z06's Avatar
PRE-Z06
not sure...that is why i wanted to go to ennis this weekend for a private rental but since my clutch is messed up i may not make it...would be nice to compare crandall traps to ennis trap speeds
yeah, the new camaro said he was trapping 2-3mph slower in the 1/4from the previous weekend we where at ennis with the same mods...comparing 2 slips where I ran 98mph in the 1/8 at both and the clutch stuck trying to go into 4th, so I just coasted to the 1/4 and trapped 4mph slower at crandall...it only makes your runs that much more impressive! If I'm in town this weekend, I'm going to Ennis Satuday as I got the bigger injectors and hardened shaft now.
Old Nov 10, 2009 | 09:21 PM
dsp300c's Avatar
dsp300c
i will try to be at ennis...depends on what is wrong with the clutch...took it in today after to work...cross my fingers and see what happens
