Tires
Old Dec 22, 2009 | 07:51 AM
follow's Avatar
follow
Navigator
Default Tires
I hate my runflat tires that came on my car. I have a 2008 by the way.
What tires is everyoen using from the BEST runflat tire to the BEST non run flat tire.
Thanks for the replies and again, I can't wait to get new shows already. I just want some experience from the people out there.
Thanks,
Joe
Old Dec 22, 2009 | 07:49 PM
gmccreary's Avatar
gmccreary
I replaced my Goodyear run-flats with BF Goodrich KDW II non run-flats. A little more road noise but they handle better in both the wet and dry.
Old Dec 22, 2009 | 08:03 PM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
How many threads are there that ask this question?
Old Dec 22, 2009 | 08:18 PM
Richor's Avatar
Richor
CF Lifetime Member
No sht, people need to learn how to use the search button
Old Dec 22, 2009 | 08:49 PM
jmudreamvette's Avatar
jmudreamvette
He's a junior member,cut him some slack....He probibly don't know about the things that can be found on this forum...
Old Dec 23, 2009 | 02:47 PM
bps999's Avatar
bps999
Opinions vary alot on this... The traction you get is very sensitive to temperature of surface and tire. I am learning that it is even more sensitive than I thought. I dont know what specifically you hate about your current tires, but pay close attention to the effect of temp. before spending money. Even the best tires are subject to poor traction if the surface is poor or the temps are too low. Some performance tires are designed to have max grip at racetrack temps that you will not reach on the street...
Old Dec 23, 2009 | 03:14 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Thanks,
Joe
Joe.....don't let the "flamers" bother you. I swapped out the GY Supercars for Nitto Invo's. Very pleased with the grip & road feel plus much less road noise (and a cool tread pattern). Lots of good rubber out there though & you'll get many differing opinions.....good bet would be to check with your local Vette club.
Old Dec 23, 2009 | 03:24 PM
STROKD's Avatar
STROKD
If you are are on a budget...
runflats Kuhmo MXs runflats
non runflat Nitto Invo
If you have a little more money
runflats Michelin Pilot Sport 2 runflats
non runflats Michelin Pilot Sport 2s
To Tires
