DOT Tire Codes
Old Dec 25, 2009 | 04:41 PM
important's Avatar
important
Default DOT Tire Codes
I'm trying to determine the age of my tires.
I searched the threads as well as the internet and found some basic information on tire dates but nothing that resembled the markings on my tires.
The fronts read: DOT M6AW DBDR
and the rears: DOT M6XD DBDR
Can anyone translate? Thanks and Merry Christmas.
Old Dec 25, 2009 | 04:57 PM
glass slipper's Avatar
glass slipper
http://www.tirerack.com/tires/tirete....jsp?techid=11
You need the four numbers after the last set of letters in your sequence above.
Old Dec 25, 2009 | 04:58 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Go two more circles or bubbles over until you see only a 4 number circle. For instance, the third bubble over on mine says, 1908, meaning 19th week of 2008.
Old Dec 25, 2009 | 05:24 PM
important's Avatar
important
I posted the pic above. It aint there...
Old Dec 25, 2009 | 05:49 PM
tclhb's Avatar
tclhb
Maybe it's on the inside of the tire?
I just had a set of Firestone wide ovals installed yesterday. I found the tires are on the L. side are not marked either. The ones on the right are 38th week of '09.
These tires are unidirectional, but all 4 have arrows in the correct direction.
Odd?
Old Dec 25, 2009 | 06:17 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Many tires are marked only on the inside. Look inside and find the numbers.
Old Dec 25, 2009 | 08:17 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
That's true, it could be on the inside as the DOT requirement is only on one side of the tire and frequently it's the inside. However, I have had another brand (Bridgestone) where they acknowledged there was NONE on the tire at all. No Build Date inside or out. And due to their wear pattern and handling, after much "conversation" they gave me a new set and said don't ask again. Nice huh?
Old Dec 25, 2009 | 10:03 PM
TEXHAWK0's Avatar
TEXHAWK0
The date code is only on the inside of the tire.
Old Dec 25, 2009 | 10:42 PM
ByByBMW's Avatar
ByByBMW
Not true, one of my 4 tires has the code on the outside, 4807 if you are curious. The other 3 are on the inside.
Old Dec 26, 2009 | 02:42 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
no, not on every tire, and not even on my C6.
Old Dec 27, 2009 | 01:09 PM
tclhb's Avatar
tclhb
Odd?
Talked to tire shop yesterday. The Firestones are made so they can be rotated left to right side after dismounting from wheel. All 4 tires are marked on the same side of the tire with the date code.
Old Dec 27, 2009 | 09:24 PM
TEXHAWK0's Avatar
TEXHAWK0
On the asymmetric tires I have seen, the code is on the inside. If the tires can be mounted both directions on the wheel, the code could be on either side. I can see where directional tires could be either, depending on which side of the car they are on.
To DOT Tire Codes
