Building an LS3 engine from scratch?
Old Dec 26, 2009 | 01:37 PM
Tork Stik's Avatar
Tork Stik
Default Building an LS3 engine from scratch?
If you start with a bare block LS3 and are willing to put around 12,000-14,000 into it, how much reliable (i.e., no boom after 25,000 miles) hp would you expect a reputable engine builder to make with it? 550-600RWhp? more/less?
Old Dec 26, 2009 | 02:06 PM
BigMay60's Avatar
BigMay60
How much "reliable" HP are you looking for? When you start from a bare block you have alot of options. Is FI out of the question?
Old Dec 26, 2009 | 03:25 PM
Tork Stik's Avatar
Tork Stik
I'd rather not do FI.
I realize there are a lot of options, but I'm just trying to get a rough baseline of what range I would be looking at with that much money invested. Obviously different builders will use different parts and different shop rates, but it'd be nice having a rough generalization going into this so I know if I'm getting the bum-end of the stick or not.
Ideally I'd like to make as much power as possible, without needing any major maintenance for like 60k (or flat out going boom sooner )....so I guess by reliable I mean it isn't going to grenade, and I'm not going to have do stuff like pull off the heads every 5k.
FWIW it's mostly going to be street use, so 95% of it's life will be below 3500RPM (so it won't be spending those 60k miles banging off 6600 all day long)
Old Dec 26, 2009 | 03:30 PM
kelp's Avatar
kelp
sleeve and girdle it. Do a 6 bolt main. Should be ok to 900 hp.
Old Dec 26, 2009 | 04:11 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
With those horsepower goals I'd say you're going to need to sleeve the block and up the displacement to 408 or 418. You're probably also looking at aftermarket heads and a cam in addition to all the regular bolt-ons.
San
Old Dec 26, 2009 | 05:04 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
Expect
1.4-1.5 hp/ci for a mild street engine
1.5-1.55 hp/ci for a moderate to aggressive street engine
1.55-1.6 hp/ci for a radical race engine
1.6+ for something very exotic
These are for naturally aspirated LS engines. Anybody who tells you otherwise is dreaming or clueless.
__________________
Contact:
(e) zach@katechengines.com
Old Dec 26, 2009 | 05:12 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Originally Posted by Katech_Jason
Expect
That's a very usefull guideline. Thanks.
San
Old Dec 26, 2009 | 05:38 PM
timd38's Avatar
timd38
For $14K why not buy a new LSA engine in the crate with 550HP?
Old Dec 26, 2009 | 05:56 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
The OP wants N/A power.
San
Old Dec 27, 2009 | 12:12 AM
Tork Stik's Avatar
Tork Stik
Expect
So around 650ish to the flywheel; not bad then.
- not n/a
- I want to run a really aggressive cam; I love the LOPEY LOPEY. No point buying a crate engine and then tearing into it
- I could probably end up with +100ish hp starting with a bare block, comared to the LSA.
Old Dec 27, 2009 | 11:01 AM
Katech_Zach
I don't know what displacement or level you're basing that on, but please note that my estimates are at the flywheel.
Old Dec 27, 2009 | 11:57 AM
old motorhead's Avatar
old motorhead
550 to 600rwhp and you're going to spend 95% of your time under 3500rpm? Any engine capable of 550+rwhp is going to run like $hit on the street. It will be fun for a while, but will get old quick. You need to either rethink your power goals or strongly consider F/I. 550Rwhp won't take anything exotic with 8psi blowing into it. It will live a long time too. That, and still retain perfect street manners.
Old Dec 27, 2009 | 01:23 PM
Tork Stik's Avatar
Tork Stik
Most LS3 shooting for power (and using a very aggressive and lopy cam, etc...) seem to be 418s, so 418*1.55 = 650ish (to the flywheel)
I have to disagree with that. I have a 408 (n/a ford 351w stroker) with a racing-style clutch (off/on quatermaster) that makes 500RWhp and while it certainly doesn't have good street manners compared to a factory z06 or viper or civic or whatever factory car you want to insert here, it definately doesn't run like crap. It's just a different driving style, that's all.
Old Dec 27, 2009 | 03:13 PM
old motorhead
It's OK to agree to disagree. You sound like you know what you're getting into. At 460rwhp n/a, my LS3 vette had more bad manners than what I'm willing to put up with. Tastes differ. You're wanting 90 more rwhp at a minimum. Now, I'm at 670+ with near perfect street manners. I wish I had gone F/I to start with, but it's kind of a big bite to begin with. Cam and heads sound less expensive....and they are if you stop there. Good luck with your build. It sounds like you'll need more cubes and some really good heads to get where you're wanting to go.
Old Dec 28, 2009 | 03:04 AM
Tork Stik's Avatar
Tork Stik
Oh yea, I'm expecting atleast 418 and big heads. As I said initially, I have a rough idea, just never built and LS with somebody before so I want to make certain I have a rough idea of what' shappening and smoke doesn't get blown up my butt
Call me crazy, but the aspects of 'radical' engines that most people consider ill-mannered - e.g., MASSIVE come lope - I just loooooooove
To Building an LS3 engine from scratch?
