Tpsm craziness !!!!!!!!!
I have two sets of stock wheels both comp grey (I think that means they can't be too old). One for track and one for street.
I have the Ateq VT10 sensor programer about 1 year old with brand new battery.
I'm going to explain in detail what happened so I don't miss anything and then I hope someone can advise me what to do.
Last night when re programing track wheels I got to the last wheel (LR) and it would not finish the programing. Tried several new batteries. Then rolled one of the street wheels up next to the (LR) tire and the programing finished properly with two honks.
Unfortunately, the programing doesn't stick and after about 20 minutes the computer falls out of Comp Mode and AH makes life impossible.
So on the way to the track I got the DIC message and dash light. At the track I pulled up close to another C6Z and used his wheel to program the (LR) and all was good for 30 minutes. Next session the after reprograming again computer kicked me out of Comp mode after 10 minutes. Then the next session the (RF) decided to do the same thing so now I needed two cars with me sandwiched between to full the computer and get me reprogramed and into Comp Mode. Then the next session I only needed to use the (RF) but used some else's programer (don't know the name. Then when I got home I had to use two street wheels (LR and RF) with my Ateq to complete program.
So what the hell is going on? Do I have one bad sensor or two? Is this common? Could it be my cars computer or could the programer be partly to blame.
I have no problem with the street wheels.
If I had a spare TPSM (not mounted to wheel) could I use it to fake out the computer for more than one wheel or would I need two different sensors to do it. Want to be prepared for next time or be able to help someone else from going thru this crap.
Thanks,
DH
DH
DH
DH
Make sure you know where the sensor is positioned on the wheel. If you have a 'non-conventional' wheel where the sensor is banded deep inside make sure you mark its position so you know where best to position the TPMS tool. In some instances the sensor might be too deep for the tool signal to reach...you might have to break the tire loose from the rim and position the TPMS tool close to the sensor set it. Hopefully, your sensors are postioned in a more convential manner close to the valve stem.
I don't know anything about your TPMS tool but make sure its set on the right continuous wave frequency. Perhaps your TPMS tool has somehow changed frequencies or if the tool is hunting for the right frequency perhaps you're letting learn mode time-out.
It hasn't happened in a long time but years ago I had couple instances where I couldn't get the final/Left Rear TPS to register properly. I even went on the track once knowing the final sensor wasn't set...it was downright dangerous with the nannies kicking-in at every corner. I exited after one lap and got the sensor registered properly.
When I couldn't get the final sensor set I would shutoff learn mode, the TPMS tool and then start the entire procedure from the beginning going around to each wheel in proper sequence. I would make sure my TPMS tool was set to the proper continuous wave frequency. In the few instances when I couldn't get the last sensor set, I had to cycle my tool through its various settings/frequencies to make sure it was on the proper continuous wave frequency and then it worked fine.
I suggest you keep trying making sure everything is being done correctly before replacing a sensor. BEZ06 is the resident forum expert on the subject. If he doesn't jump-in you might want to PM him and ask his opinion. Good luck!
I am planning on backing it out of the garage so my spare wheels with sensors are not around when I mount the troublesome ones and try to reprogram.
Sensors and wheels are stock so I either aim right into the valve stem which has always worked or thru the tire which seemed to get the programing done on the LR sensor last time I tried.
DH
at the sensor through the tire... NOT via the Stem or through the Wheel.
It works every time for me.
By the way, for my 2007 the sequence is LF, RF, RR, LR.
http://forums.corvetteforum.com/1565322491-post2.html
All my sensors were working good.
I now aim thru the tire and haven't had a problem since
DH
The system doesn't know which direction the pressure signal is coming from, which why there has to be a programming order in the first place. You're telling it which sensor is in which position.
That is how I do it also.
