Anyone Using the Sprint Booster Power Converter
#41
Okay, here's the deal.P.S. when I purchased the car I wasn't completely satisfied with the way the panel responded for a 400 hp car. I also was thinking about installing a L Brock supercharger which said they would cover the warrant for of course an additional price however after purchasing this little stupid plastic device I am happy with the how the car feels and will not be making any changes
David
David
#42
I think this is a good post, and well stated. I think too many people forget that frankly, if you're not racing your car and going for the last tenth in some sort of measured event, then the SOTP feel of the car is what you are really buying with performance mods. If this device makes the car feel faster and that's what you were looking for,and you don't care about measured racing events (drag, road course, street (not recommended)) then it's a good mod.
Drive the car more aggressively and you're getting the same results.
#43
You have a good point. However, the "feel" of the car means a lot. I used to put lighter accelerator springs on my old school carb cars to make the car "feel faster" when I was a young HS/College guy with no money for mods. We used to also put on modified steering boxes with quicker ratios so that the steering was quicker and harder...in fact some cars had two places on the pitman arm, and you installed the linkage depending if you wanted quicker (and harder) steering or slower and easier steering.
#45
Thank You, Well Put
#46
I could write another page long reply but to keep it simple definitely does not feel the same.
#47
If buying sand in a bottle for $300 makes you feel like you're at the beach, I'd still say to spend the $300 on a ticket to Miami and put the sand in your own bottle... In other words, put some nitrous in your car.
#48
Had it coming
if I want to void my warranty and add the horsepower I would have however this is a solution for not adding 150 hp and voiding your warranty. My opinion only as I said each their own. I drive the car and like the comfort and reliability on long trips to Santa Barbara. Do not race the car or even put it on a track. If I did I would not have bought a grand sport I would have bought a ZR1.
#49
#50
New recorders
Your warranty isn't automatically voided because you add power to your car. That is a common misconception. In order for your warranty to be voided the dealer/manuf must show that your modification is what caused the breakdown of the particular part which has broken. This means that if your motor blows tomorrow and the manuf alleges and can prove by a proponderance of the evidence that your modification, which is well documented on this website, caused it to blow you are out of luck as well... my suggestion... get a second stock intake, put a hole in it, attach a nitrous fogger to it and keep your stock one without a hole.. if something blows, take out the juice and replace the intake w/ the hole. though I would NEVER do that to my leased cars
#51
I wouldn't put it past government motors to do that. Again, it's kind of tough for them to prove that nitrous was sprayed. They'd likely need a lawyer, an expert, and some some lab work to prove that there was anything ever sprayed into the motor at all.. and who's to say you didn't run into a pocket of someone elses purge on the road... Gotta love the justice system.. eh? Either way it'll be cheaper for them to give you a brand new car than to go through the trouble of fighting it and most likely losing.
#52
Toyota recall
The 06's and up have a similar relationship between the pedal position and the throttle body opening. Unfortunately HP tuners etc have not addressed this. I bet they won't now that Toyota is having issues. Just imagine some knuckle head reprograms this parameter and goes out and has a wreck and someone finds out the acceleration table was changed. The lawyers would have a field day.
#53
just a little spotlight on Toyota, they never had a problem this was all a news media hype for every Toyota owner that wanted to get out of a ticket at 100 miles an hour on the freeway. NASA did a year-long study showing that there was nothing wrong with the foot pedal as for the accident in San Diego with the California Highway Patrol man this was due to the fact that all weather floor mats got stuck under the pedal and caused it to stick. If you ever had to deal with the media you will find that most of their ratings come from hype. Do you remember when the pit bulls were killing everybody. This is all you heard on the news for months has something changed does nobody have pit bulls now??
#54
It actually hurt me at the drag strip because it was causing my car to lurch forward (almost pushing me through the beams before the tree sequence started) while trying to stall it up to cut a good light.
If I wanted firmer seats I wouldn't buy new ones, I would simply pump up my tires more LOL.
#55
If there was no actual problem then why did Toyota technicians/engineers spend so much time trying to fix it? At one point even admitting that they'd discovered the problem (that supposedly didn't exist in the first place?) and had fixed it, blaming a supplier and not themselves of course.
Were they so desperate to get the focus off of the issue that they'd say anything just to try to put (spin) the public at ease?
It's not just the big bad media that does it, huge international corporations with LOTS to lose do it too.
Hype and smoke & mirror tricks work both ways too ya know.
#56
'sprint booster' = $10 scam with a $300 price tag.
http://www.crosslake.net/~dbipes/spr...intBooster.pdf
#57
That was a nice technical piece to explain what most of us already know.
The sprint booster does nothing that pushing your foot down 30% harder wouldn't do.
