LS3 block/stroker questions
Old Jan 14, 2010 | 09:42 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Default LS3 block/stroker questions
Can't find specific answers, so I thought I'd ask here...
Is a 4" LS crank a direct drop in for the LS3? Or does the block or rod ends need clearanced?
I'd like to keep the stock size pistons and rods, just with the longer stroke crank for a 416ci.
Wouldn't is simply be easier to put a new crank in the stock block rather than switch everything over to a whole new shortblock?
I'm just wondering, because I see all sorts of shortblocks available. But nobody really just doing a crank swap (sounds so easy, huh? lol. ) with the stock pistons or rods. I'm guess that it must be an enormous p.i.t.a. compared to an ol' SBC.
Thanks for any insight. I wish there was a class I could take, or something. haha.
Old Jan 14, 2010 | 10:45 PM
wooden's Avatar
wooden
I believe there is alittle that needs to be taken off the bottom of the cylinders for the longer stroke, I bought the short block assembled so not exactly sure how much needs removed but I don,t think it is much. I am sure you could do it fairly easily yourself.
Old Jan 14, 2010 | 10:47 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
If you were to simply increase the stroke, the piston would ram into the head. You have to change the stroke and the pistons so that the new pistons have their wrist pin higher up, increasing the stroke length but not the piston's height in relation to the top of the deck.
As far as a class... I wouldn't know, but there are many *excellent* books on the subject.
Here is one:
Old Jan 14, 2010 | 11:43 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Yeah, piston/valve contact wouldn't be an ideal situation.
Thanks for the recommendation, I just ordered it.
Old Jan 15, 2010 | 01:38 AM
SpinMonster's Avatar
SpinMonster
You can sell your LS3 for 2500 or so for the shortblock and Lingenfelter sells the 416 starting at 5100.
Figure 6k with crate, shipping, upgraded pistons, and a good timing chain.
I have a great cam for it. Using your LS3 heads it will hit 540rwhp or 570 with a Trick flow 235.
To LS3 block/stroker questions
