Weak Rear Axles
Old Jan 23, 2010 | 04:42 PM
chsmith112's Avatar
chsmith112
Default Weak Rear Axles
Well I guess my axles twisted and ended up snapping not too long ago, so I replaced them with some solid C5 z06 rear axles. Anyone know if this is just a one year thing with the 05s that they are hollow or is it all c6s? I think it's the axles that I snapped I don't quite remember exactly what he said. Make sense to anyone?
Old Jan 23, 2010 | 04:53 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I don't believe any Corvette axles are hollow. Are you sure about this?
Old Jan 23, 2010 | 05:04 PM
chsmith112's Avatar
chsmith112
That's what I was told......maybe it's just an 05 thing. I don't see how they would have twisted an snapped in the first place tho. I usually baby the thing.
Old Jan 23, 2010 | 06:37 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Does your car wheel hop? How much power are you making?
Old Jan 23, 2010 | 11:06 PM
JoesC5's Avatar
JoesC5
I believe that all the C5's and C6's have solid axles. I believe they changed the design of the CV joints with the C6 and they turned out to be weaker then the design used in the C5. Changes were made in the C6 CV joint design.
Old Jan 24, 2010 | 11:55 AM
CMY SIX's Avatar
CMY SIX
the C5 Z06 axle is better! and is the axle of choice when you break a C6 axle
Old Jan 24, 2010 | 02:08 PM
chsmith112's Avatar
chsmith112
Im making 443/420 with stickier tires than stock.
Old Jan 25, 2010 | 03:15 AM
SpinMonster's Avatar
SpinMonster
Have you ever reTQed the axle nuts since you bought the car?
If so what did your TQ to?
Old Jan 25, 2010 | 11:42 AM
chsmith112's Avatar
chsmith112
No I have not, not that I am aware of........they probably did it after intalling the new axles tho.
Old Jan 25, 2010 | 07:40 PM
timd38's Avatar
timd38
I just installed the SKF performance bearings and used new nuts with the recommended Loctite to the new TQ spec of, if I remember right, 135 fp.
To Weak Rear Axles
