header recomendations
Old Jan 25, 2010 | 10:18 AM
hitecredneck's Avatar
hitecredneck
Default header recomendations
I'm still confused on what headers to use for my 07? car is tuned, aftermarket exhaust(calloway), intake. Used for crusing, car shows. would also like to find a used system to save $$.
Old Jan 25, 2010 | 11:25 AM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
You can not go wrong with buying a set of headers from Kooks, ARH, or LG. Just get the matching x pipe from the header manufacture you go with.
All of them will show similiar gains if you compare the same primary and collector size.
Old Jan 25, 2010 | 12:05 PM
almighty.peanut's Avatar
almighty.peanut
i just made a thread about my experience with LPP stainless headers. i got the headers & catted midpipe for $750 shipped and the quality is excellent. my buddies were finding it hard to believe they were only $750 new.
Old Jan 25, 2010 | 08:50 PM
HuskerBullet's Avatar
HuskerBullet
Whatever headers you get, I highly suggest you have them Jet-Hot coated.
Old Jan 25, 2010 | 09:27 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
For your stated usage, a set of 1 3/4" pipes will be more than sufficient.
I just ordered a set of 321 titanium stainless steel 1 3/4" headers w/ catted 3"-2 1/2" xpipe from JW Motoring plus high-temp O2 extensions and was out the door for less than $1000 including shipping.
If you don't need cats, knock off $125.
Old Jan 25, 2010 | 10:36 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
You can't go wrong with these headers
Old Jan 26, 2010 | 02:50 AM
ls3atomicvette's Avatar
ls3atomicvette
I used the kooks 1 7/8 on my 08 vette with the non catted x pipe i bolted them in with a buddy the install took 45min and that was on the ground with no lift. they went in perfectly zero clearance issues. i think any of the above headers are all great i found the kooks the cheapest.
Old Jan 27, 2010 | 11:21 AM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I would be more than happy to assist you with any questions you have about our products.
Keep in mind unless you specifically ask for our headers by themselves all of our kits include X pipes, and all necessary hardware, piping, and wiring to bolt the system onto your with no other modifications.
Old Jan 27, 2010 | 04:39 PM
mlc331's Avatar
mlc331
I posted on my headers from LPP as well. They were simply OUTSTANDING! Couldn't of went any better. Mufflers will be your next issue. What will you use??? Drone becomes an issue with ALL HEADERS depending on mufflers...
Good luck man
Old Jan 27, 2010 | 05:03 PM
s ladd's Avatar
s ladd
I would vote against kooks just because I thought the 2 slip fits to be a PITA. Next time I will be getting either ARH or LG's.
Old Jan 30, 2010 | 10:38 PM
Hogvette's Avatar
Hogvette
Good luck man
I have the NPP exhaust which I'd like to keep... are the Kooks compatible with my NPP exhaust without undue modifications?
Anyone else have this problem? I was leaning towards the Kooks until I read this post...
Old Jan 30, 2010 | 10:52 PM
ls3atomicvette
I have the npp exhaust too just make sure you buy the same brands for the x pipe and headers. I did not have problems with the slip fits
Old Jan 30, 2010 | 11:20 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Yes, I remember spending some time getting them. They were very tight
but great headers. I vote ARH or Kook's!
Old Jan 31, 2010 | 12:25 AM
0HorsePowerAddicts
Former Vendor
The kooks x pipe will work with the NPP exhaust. I have never had a slip connection not fit. Better to have a tight connection than a loose one.
Old Jan 31, 2010 | 09:37 AM
rws.1's Avatar
rws.1
ARH was my choice
Old Jan 31, 2010 | 01:40 PM
EATURAW's Avatar
EATURAW
Kooks going on my 08 LS3 on Tuesday - Along with an AirRade, 160 T-stat, and Tune....
Old Jan 31, 2010 | 04:03 PM
Justin11b11m's Avatar
Justin11b11m
Cruising
Recommendation for an 07 m6 z51 with a Bassani Catback exhaust?
Old Jan 31, 2010 | 05:06 PM
JW Motorsports
Banned Scam/Spammer
http://www.shop.jwmotoring.com/categ...?categoryId=36
To header recomendations
