To all,
After recamming, changing out valvetrain, and tuning, this is what Vengeance did for my LS2 stroker. I have a VR ported LS3 intake, VR ported 90MM TB, Honker CAI, L92 ported heads w/ TEA comp valve job and LS3 hollow stems, VR LS3 custom cam, ARH 1 7/8 headers, and tuning. Special thanks to Vengeance for getting me right. BTW, cam only has a 4* split and I have a 3.90 diff.
THANKS TO RON, MIKE, AND VENGEANCE RACING
Mike C sends
It's a 404 CI. I originally had some head issues, had the heads rebuilt, and changed out the cam to a VR 231/235. I have TIs, so I am totally stealth. I'll be picking up my car tomorrow. I am very pleased with the results. You can see the difference going to a ported TB & intake, 1 7/8 ARHs, competition Valve job an d milling w/ replacement of stock valves to hollow stem and the right cam will do. VR was right on. You can see the before and after. Hope this helps.
Mike C sends
Spin,
I think our posts were passing each other on the Information Highway. 404 or 403, I have a 4" stroke w/ 4.010 bore, no matter. BTW, the cam is a 231/235 w/ 4* split. This split is right on. Also, the added porting of intake, TB, lighter valvetrain, and 1 7/8 ARHs, definitely helped in the increase from before. BTW, the heads flowed at 351/261 at .600. I will be real happy when I pick up tomorrow. Thanks for all your inputs on the forum, adding HP/TQ here and there does add up. Of course, thanks again to Vengeance Racing for the GREAT numbers.
Mike C sends
