PowerLabs' Battery Relocation!
Old Mar 10, 2010 | 08:21 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Default PowerLabs' Battery Relocation!
I won't do a write up here, but I have one if anybody wants, just PM me for a link.
For this install I studied the way the battery is installed and cables are run on a stock C6Z06, and replicated everything... It came out pretty nice:
21lbs absorbed matt battery tied down with a lightweight backet:
Cable Run on stock location:
Fabricated new harness with wire loom and heat wrap:
Old Mar 10, 2010 | 08:59 PM
Motorhead-47's Avatar
Motorhead-47
I gotta ask....WHY? Do you have plans for that space under the hood or are you using it to balance something else going in the other tray?
Old Mar 10, 2010 | 09:11 PM
Streetk14's Avatar
Streetk14
I'd have to guess that it would be to help restore the weight balance of the car. He has a blower system that has to add some weight over the nose.
Andy
Old Mar 10, 2010 | 09:13 PM
jsilvz's Avatar
jsilvz
Maybe a meth tank or air to water intercooler?
Old Mar 10, 2010 | 09:15 PM
SpinMonster's Avatar
SpinMonster
I did it for traction alone. Taking 43 lbs off the front of the car and putting 32 lbs over the rear tire really made a difference in my cars ability to get it to the ground. Anyone spinning the tires will gain from this mod. It gains because of the weight on the tire and weight transfer.
Guys with S/C's can set the balance back to stock. The S/C added weight up front and the battery relocation corrects the weight balance and can actually get rid of some of the weight with a lighter battery. I used a D35 optima which is 10 lbs lighter.
Old Mar 10, 2010 | 09:17 PM
SpinMonster
I have both sets of cables active so i can run it in either location. The ground was made to the frame in the back so there is no need to make a ground up front. The red power line gets connected to the front.
I wanted the space to be available for a stand alone nitrous fuel system that mounts where the front battery location would be.
Old Mar 10, 2010 | 10:26 PM
LS1LT1's Avatar
LS1LT1
Any idea of how much weight the longer cables added back in (even with that gain factored in it's obviously still a nice weight loss overall as the battery itself is much lighter than stock )?
Old Mar 10, 2010 | 11:55 PM
PowerLabs's Avatar
PowerLabs
Man, those questions bewilder me... I had to check again to make sure we were in fact in the Tech/PERFORMANCE forum and not in "General"... WHY do you have a Corvette? A Toyota Camry will take you anywhere a C6 will, won't it? A Camry will also do more than double the legal speed limit in most states in this nation while carrying 4 passengers and getting better fuel economy than a Corvette... We should all be driving Camrys?
I did this for the same reason I run race tires
And have a supercharger
And a ZR1 cam
And race pads
And Methanol Injection
PERFORMANCE
I removed 23 pounds from the car overall, and did that by adding 21 pounds over the rear tires where it helps traction, while removing 46 from the front of a car that is already somewhat nose heavy from the factory. The Z06, the ZR1 and the GrandSport all have their batteries in the back for that same reason: better weight distribution, more traction and a cooler environment for the battery where it lasts longer.
Old Mar 10, 2010 | 11:57 PM
PowerLabs's Avatar
PowerLabs
5.6 pounds evenly distributed from the front to the back of the car.
It is mostly about removing that 44lbs battery (and another 4lbs from the harness and tray) from the nose of the car. This is specially important to me because I have a supercharger up there and need neutral weight balance for autocross and road race events.
Old Mar 10, 2010 | 11:58 PM
Robls6's Avatar
Robls6
cool. I like it.
Old Mar 11, 2010 | 12:03 AM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Battery relocation
I've got a similar set-up with the Optima D34 Yellow Top in the rear and room for a meth set-up in front.
Old Mar 11, 2010 | 12:16 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I like it! 99 percent of all Corvettes in the world are right rear light. It's very hard to offset all of the driver's weight. This was a win-win mod in my eyes.
Randy
Old Mar 11, 2010 | 12:34 AM
chazc6's Avatar
chazc6
St. Jude Donor '10
From what i understand, when the battery is relocated to the trunk the weight of the battery increases almost double while launching. Instead of lifting a 43 lb battery when its in the front, the 32 lb battery is close to dropping a 64 lb battery on the axle or half shafts, depending on how quick, and how low the car squats.
Old Mar 11, 2010 | 12:59 AM
PowerLabs's Avatar
PowerLabs
I kept my stock harness too so I could go back to a front battery if I wanted to.
I grounded my battery to the frame on the back too, but I ran an additional ground between the engine and the frame to prevent ground loops through the drivetrain; not a concern if you kept your stock wires, but definitely one if you remove them...
Old Mar 11, 2010 | 02:34 AM
carlrx7's Avatar
carlrx7
very nice,, ive been wanting to do this for a while now, but ive heard if you relocate you need a battery cut off at the drag strip,, i guess i could just tell them it comes like that from the factory. hmmm
like what you did with the ground wire,, you can NEVER have enough grounds.
-Carl
Old Mar 11, 2010 | 03:34 AM
LS1LT1's Avatar
LS1LT1
And lately some Toyota Camrys have even been doubling that speed limit whether their owners liked it or not LOL.
Nice, definitely a worthy mod.
Old Mar 11, 2010 | 04:04 AM
SpinMonster
"Officer, I swear I wasnt trying to speed, I think the gas pedal is needing the recall"
You think it will work? Im sure its been tried.
To PowerLabs' Battery Relocation!
Old Mar 11, 2010 | 04:15 AM
timd38's Avatar
timd38
If I didn't work for the company that makes Optima's, I would move mine....
Old Mar 11, 2010 | 04:32 AM
filmjay's Avatar
filmjay
St. Jude Donor '10
Nice. I've been thinking about doing just this.
But a question if I may...Shouldn't it be on the drivers side to counterbalance the cross weight?
Old Mar 11, 2010 | 04:38 AM
lockman's Avatar
lockman
ok so that might be a little scary if you work for them and won't put your battery back there is your quality control that bad ???
