Help with pushrod length..
Old Mar 14, 2010 | 08:37 PM
silvervette05's Avatar
silvervette05
Default Help with pushrod length..
I am installing spins 230/234, 612/598 cam next week and i wanna make sure i get the right pushrods..Do i need to stay with the stock 7.400 or what? Thanks..
Jonathan..
Old Mar 14, 2010 | 09:00 PM
cranky's Avatar
cranky
on most all of the cam changes on these, the 7.425 length works very well. you may get just a little tiny bit of noise, but they should be fine.
Old Mar 14, 2010 | 09:30 PM
Bad News's Avatar
Bad News
I have done many searches on this subject and the most common answer that I heard is that you really should measure for new pushrods using a pushrod length checker. I got a lot of responses saying that "x" length pushrod "should" work, but I decided to spend the $12 on a length checker and measure myself for peace of mind.
Old Mar 14, 2010 | 09:38 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Measuring is the only way to know for sure.
Old Mar 14, 2010 | 10:21 PM
c6 batmobile's Avatar
c6 batmobile
Measure em!! Its only 12-16 bucks for the tool and it will let you know dead on.
Old Mar 14, 2010 | 10:58 PM
silvervette05
thanks guys, but how exactly do i measure em?? I've never done it or seen it done..
Old Mar 15, 2010 | 07:19 PM
glass slipper's Avatar
glass slipper
http://www.compcams.com/Technical/FA...inGeometry.asp
Make sure you get the correct range "checking" pushrod for your application. The folks at Comp Cams should be able to tell you which one to get, I always go to them and they haven't missed yet. If you don't understand the info in the link above, I'm sure somebody at Comp Cams will help you but it's really not that difficult once you get into it.
To Help with pushrod length..
