Z51 Rotors Turned?
Old Mar 30, 2010 | 12:31 PM
mariomark's Avatar
mariomark
Default Z51 Rotors Turned?
I dropped off my '06 Z51 this morning for new brake pads at the dealer. They just told me that my rotors do not need to be turned. There are heavy grooves in a couple of them. I specified I wanted the same pads that came with the car and I'll deal with the dust. Will this be O.K. without turning the rotors? Once and a while I track this car and I need it to brake perfectly.
Old Mar 30, 2010 | 12:39 PM
jmoffett's Avatar
jmoffett
Doing a brake job without turning the rotors is like putting on dirty underwear after taking a shower.
Old Mar 30, 2010 | 12:54 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Turning is old school. Check the service manual, they have you replace the pads and perform a pad and rotor burnish. Less chance of messing the rotors up.
Old Mar 30, 2010 | 01:06 PM
Walt White Coupe's Avatar
Walt White Coupe
The tech manual says that allowable grooves (scoring) are up to 0.059 inches in depth but if "excessive" scoring is present (I guess that means a large number of grooves even though they are under the limit) they should be resurfaced or replaced.
Personally, I'd have them turned if there is acceptable thickness after turning.
Old Mar 30, 2010 | 02:29 PM
glennhl's Avatar
glennhl
I never turn my rotors unless for some reason the pads wore completely out and I got metal to metal contact.
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Turning rotors is like a band aid. I would go with new rotors or use the old ones and bed the pads. You should have no problem if you are using factory pads. They will be the same compound so there compatiable with your old rotors.
Old Mar 30, 2010 | 03:04 PM
mariomark's Avatar
mariomark
Thanks, I've never had drilled rotors before and was unsure if they could be turned or if they needed to be. My only experience with rotors on a Vette was replacing the parking brakes in my '77 and it involved a slide hammer on both rears.
Old Mar 30, 2010 | 05:48 PM
mariomark's Avatar
mariomark
They replaced my pads with part numbers 88909667 and 19169649. Brakes feel fine in traffic, I also had my trans flushed. The last time I had this car on the track my trans temps reached 268 degrees. This is why. http://www.youtube.com/watch?v=ss1mWr-QfGU
Old Mar 30, 2010 | 10:09 PM
VET4LES's Avatar
VET4LES
I've done my own brake jobs for over fifty years. That's before disk brakes were standard on auto's. Only one time have I turned the rotors and that was due to them being warped.
Old Mar 30, 2010 | 10:17 PM
Walt White Coupe
OK, save a few bucks on grooved rotors and the brakes will work just fine. But you may have forgotten how nice new brakes on new or resurfaced rotors feel. The application of brakes is simply smoother and I'll pay for that.
Old Mar 30, 2010 | 10:31 PM
jmoffett's Avatar
jmoffett
I guess I stand corrected...
Old Mar 30, 2010 | 10:33 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I suggest doing a Google search on "sandpaper+rotors".
It seems pretty common and widely acceptable to use sandpaper on the rotors if a) they are not warped and b) no excessive grooves. My 1996 Corvette Helms manual recommended sanding them if they were in good shape.
I recently did the brakes on our daily drivers (non-Corvettes) and my wife's Lexus, I just installed new pads and did not touch the rotors. My car, a Mercedes ML55 AMG, I had a rusty set of OEM Mercedes rotors that I removed 2 years ago during the last brake job that I took to the local brake shop and had them turned only to clean them up and get the rust off.
I sanded then with 100 grit paper to remove the machine marks, washed them with Simple Green, and then wiped them down with denatured alcohol.
I looked at the Corvette rotors the other day and they look great. If they look that way when the pads are worn out, I'll just sand them down and install new pads. 100 seems to be about the right grit. Use an orbital sander if you have one.
One thing you have to worry about when getting new rotors or getting old ones turned is excessive run-out. So don't be afraid to just sand them down and put new pads if they are in good shape.
Old Mar 31, 2010 | 09:17 AM
Eric D's Avatar
Eric D
Ok, if you want to turn your car’s rotors go for it, it is your choice. But why remove material shorting its service life when it isn't needed? There is a risk that removing the rotor for resurfacing can screw up the friction surfaces of the rotor. Granted, if the rotor has seen metal on metal, like in the case of the brake pad material missing, then you might want to turn the rotor, but even then, on vehicle resurfacing is preferred over removing them. If I personally have this or if the rotor is worn near the limits, I would rather replace it with a new rotor.
As far as braking quality, there is no difference if the new pads are bedded in properly after installation compared the turning the rotors just for the sake of replacing the pads.
Old Mar 31, 2010 | 10:07 AM
jmt1669's Avatar
jmt1669
St. Jude Donor '11
I didn't think you could turn/cut Z51 rotors?
Old Mar 31, 2010 | 10:09 AM
Walt White Coupe
You can.
Old Mar 31, 2010 | 06:17 PM
WCLW's Avatar
WCLW
You can.
It's what us machinists call an "interrupted cut" on the lathe, but I've done cuts like that on parts before (never brakes though). It's just a little harder on the cutting tool bit because it introduces impacts to each revolution.
read this: http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Apr 1, 2010 | 03:11 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Changed my Z51 pads without turning or sanding rotors. Worked out fine. Just bed the new pads properly.
To Z51 Rotors Turned?
Old Apr 1, 2010 | 07:20 PM
Mez's Avatar
Mez
Yes, that works too. The reason for sanding is to aid in the bedding process by removing old pad material embedded in the rotors which sometimes cause brake squeal with new pads.
If the brakes do not squeal, the pedal does not pulse, and it stops as it should then you should be fine.
Old Apr 1, 2010 | 07:48 PM
vettemann62's Avatar
vettemann62
On all my cars, I only have them cut if the brakes had worn through & grooved them or they got warped. Other then that, I use sandpaper on them. Why shorten there life span if you don't have to.
I do agree though that they feel pretty nice after a good cuttin'
Old Apr 1, 2010 | 08:09 PM
Bill Dearborn's Avatar
Bill Dearborn
I just throw a set of pads on if the rotors aren't excessively grooved. Have been doing that for close to 40 years without turning rotors. It is even hard to find someplace that will turn rotors nowadays. Used to be that every auto parts store had the ability to turn drums and rotors. I don't know of a single store in my area that has the ability to do that now.
Bill
