FAST 102 on an LS2
Old Apr 9, 2010 | 05:40 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I understand there will be a small amount of prep work (drilling a hole, and removing a little tape to to gain a little extra length for a wire to connect and that is about it) I should be able to shed some light on this after this weekend.
No issues for clearance of the firewall which is very nice!
Old Apr 9, 2010 | 06:44 PM
Finster07's Avatar
Finster07
Originally Posted by Barrys Vette
I just finished my install around 2 weeks ago, LG headers with cats, Z06 catback, Callaway Honker, FAST 102 with ported throttle body and I dynoed 399hp/392tq.
I have been trying to decide if it is worth upgrading my ported FAST 90 to a FAST 102. With my ported FAST 90, I was making 400rwhp/400rwtq with kooks headers and a ported tb. It doesn't look like I will gain much at all going from the 90 to the 102.
Since then, I have installed heads and a cam, but I still have the ported FAST 90. Heads and cam gives me 488rwhp/450rwtq on a mustang dyno through 3.90's.
Old Apr 9, 2010 | 08:26 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Originally Posted by Mikeg4572
Does anyone have any results on the FAST 102 on an LS2 with stock 243 heads? I have seen some on an LS2 with aftermarket heads.
I'd really like to see some track results but dyno results are ok too.
Thanks!
Just dynoed my LS2 w / FAST 102, Stock heads, and cam. I plan to go to the track soon and will post results.
http://forums.corvetteforum.com/c6-t...ast-102-a.html
Fits perfect, easy install.
Old Apr 9, 2010 | 08:43 PM
SL33PER's Avatar
SL33PER
I will be waiting to hear!
Thanks!
Old Apr 9, 2010 | 08:46 PM
sallen619's Avatar
sallen619
Originally Posted by Neumonic2002
I am installing one tomorrow on my 06', I bought it Monday from Hinson and received it Wednesday!
I am taking off a stage 1 ported LS2 intake I got from Spin last year.
Currently I have A Vararam, AR Headers (1 3/4 w/cats), ported intake & TB with a street tune and make 381/382.
Not sure when I will be able to get dyno numbers as my tuner is out of town this weekend..
I have the same set-up...no ported TB...I'm eagerly waiting for your results...
Old Apr 12, 2010 | 10:33 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Originally Posted by LSCHLEM
The new FAST 102 will fit the 243 Heads without all those mods we had to do. We just don't have enough numbers yet to conclude its better than the 90/92. Fast 92's with stock 243 Heads are getting to 400 RWHP and
slightly beyond beyond. I managed to get to 408 RWHP/ 412 RWTQ
I would suggest getting to the DYNO and get some base numbers. Also
A Pro Tune will be necessary to see 400RWHP +
As far as track times LS1Lt1 and Dennis NJ have gone into the 10's. But thats not the average. 11.40 with a good set of tires and a reasonable 60'.
when do you plan to have the install completed?
Old Apr 12, 2010 | 01:28 PM
Isaiah48's Avatar
Isaiah48
I just did mine last week, no firewall issues and the fit is perfect...
However, if you have milled heads you need to check the clearance to the valley pan. It comes with 2 little rubber bumpers to put on but when I noticed that when torqueing it down that it didn't feel right so I pulled it back off and and sure enough, they looked lile they might have been touching from the marks on the valley pan. I used some clay on the bumpers as well as all the port contacts just to be sure and the bumpers were definitly hitting.
For some stupid reason, they dont come with manifold gaskets so make sure you order new ones, the directions say you can use your stock ones but mine were all stretched out and wouldn't stay seated while trying to put the manifold on.
I talked to the vendor about the gasket issues I was having and he said that sometimes they work and sometimes they dont... I can't believe that with the money these things cost that they dont give you new gaskets!
Oh, one more thing, they do give you new oring gaskets for your injectors, make sure you use them. I thought they were in there for due diligence sakes and since I had new injectors and they all still looked new, I would opt to forego changing them. IDIOT!!! I had little micro leaks at every injector port. It was kind of hard to diagnose too since using the old starting fluid trick to find the leak didn't seem to give any feedback... When I finally figured it out, I realized the orings are actually bigger for the FAST 102mm than they are for the 90mm ... I know , I know, I'll follow the directions next time.
Hope this helps someone...
Old Apr 12, 2010 | 05:10 PM
Neumonic2002
Instal went smooth, took my time and enjoyed the process...I bought the FAST gaskets and opted to use the o-rings for the injectors (sounds like that was a good thing reading Isaiah48 post) fitment was very good and boy can I tell a difference!
Unfortunately I am waiting on my tuner to free up some time to clean me up as it feels like I am lean above 5k rpm's so I will have to get re-tuned before I can strap it down on the dyno or go to the track.
Old Apr 12, 2010 | 05:17 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Congrats on your new found power. Enjoy. Leon
Old Apr 13, 2010 | 09:02 AM
mittens's Avatar
mittens
awesome! i need to get me one of these.
Old Apr 13, 2010 | 09:47 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
102 may be a future purchase!
BC
Old Apr 19, 2010 | 11:51 AM
Neumonic2002
We played with the tune for a couple hours yesterday, the car is pulling some serious air considering I still have the stock cam.
getting the AFR happy was easy but the timing has its challenges.
Might try a colder and or diff plug to see if it will help as there is a "spot" around 4500rpm's that isn't cooperating with us.
Old Apr 19, 2010 | 12:26 PM
  #33
LS1LT1's Avatar
LS1LT1
As far as track times LS1LT1 and Dennis NJ have gone into the 10's. But thats not the average. 11.40 with a good set of tires and a reasonable 60'.
Old Apr 19, 2010 | 01:59 PM
  #34
Isaiah48's Avatar
Isaiah48
I had to lower timing between 4,200-4,800, I go from 28 degrees before and after that area, down to 23-25 degrees.
I had the same issue with my FAST 90 so I'm not sure what is causing it, but I sure would like to know. I tried moving when my Power Enrichment comes in down to 3,000rpm and upped the PE fueling in that range as by as much as 15% and like I said, I'm still at 23-25 degrees...
Let me know what you find out if it doesn't get resolved in this thread...
Old Apr 19, 2010 | 04:20 PM
  #35
DSteck's Avatar
DSteck
~24º is pretty good, and typical for Gen IV LSx engines at MBT (max brake torque). I think for the amount of air being moved, though, the TR5 plug just isn't cooperating at the cylinder load being seen.
Either way, you should never run a static amount of timing across your WOT area. If you do, you are lazy. Timing should go down as cylinder load goes up... MBT happens at peak cylinder load, and since cylinder load starts dropping as you approach redline, you should start adding more timing. I typically shoot for 24º at MBT (usually around 4800rpm) and 27º at peak horsepower, which can vary... but usually about 6000rpm for stock cam vehicles.
Old Apr 19, 2010 | 07:08 PM
  #36
LSCHLEM's Avatar
LSCHLEM
Hey, Got a question for you. On your FAST 102 install was there a hole up front for you to mount the MAP Sensor ? Sounds like you guys are really
nailing down the A/f and timing down. Usually you don't have to mess with the Plugs. Just my 2 cts.
Old Apr 19, 2010 | 07:24 PM
  #37
SweetS10v8's Avatar
SweetS10v8
Yes....
To FAST 102 on an LS2
Old Apr 19, 2010 | 07:33 PM
  #38
turboffr's Avatar
turboffr
St. Jude Donor '10
Originally Posted by SweetS10v8
Yes....
there's a provision for mounting the sensor, but you need to drill the hole
Old Apr 19, 2010 | 10:08 PM
  #39
SweetS10v8's Avatar
SweetS10v8
You have to drill a hole either way. They are both shipped plugged so you can decide which one works best for your vehicle.
Check out what I found looking around....pretty cool. Lists all the parts you need.
http://www.fuelairspark.com/Company/...mSelector.aspx <----- (click here) below is just an image i stole off thier site..
Old Apr 20, 2010 | 07:03 AM
  #40
Isaiah48's Avatar
Isaiah48
Good information, I guess we weren't too far off after all...
