No Spark
Old Apr 20, 2010 | 10:36 PM
fc_soldier's Avatar
fc_soldier
Default No Spark
No spark is getting to the plugs. Ive checked all connections and dont see any issues. Its for 2005 LS2 motor. Any ideas that Ican check?
Old Apr 20, 2010 | 10:44 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
What car is it in?
Old Apr 20, 2010 | 10:51 PM
fc_soldier's Avatar
fc_soldier
Its in a 1996 corvette.
The wire harness and ECM were done by current performance wire harness. Not by me. I hooked up everything but my cruise control and I have to mount a coolant temp for my gauge, so that wire isnt hooked up.
I tried to see if I could pull a code and it says it passes. Only thing I can think of is ECM or CPS. But with CPS i should still get a spark right if it wasnt working right?
Old Apr 20, 2010 | 10:59 PM
HANNY's Avatar
HANNY
hook up a scanner and see if you can read rpm while cranking, that will tell you if the crank sensor is working. double check grounds for the ecm as well
Old Apr 20, 2010 | 11:17 PM
Mez's Avatar
Mez
Vats?
Old Apr 20, 2010 | 11:52 PM
fc_soldier's Avatar
fc_soldier
I have three grounds total that came on the wire harness and I have 3 that were on the car. Im going to def go thru each strand of harness.
Old Apr 20, 2010 | 11:53 PM
fc_soldier's Avatar
fc_soldier
Originally Posted by Mez
Vats?
I was thinking the same thing. I ready up and it can kill my starter. But what do they mean by kill it cause mine still rotates?
Old Apr 21, 2010 | 08:44 AM
Mez's Avatar
Mez
The engine won't turn over if its VATS. Do the coils have power?
Old Apr 21, 2010 | 10:45 AM
fc_soldier's Avatar
fc_soldier
My tuner said the VATS isnt the issue or wont be a issue. I have the pin out for the ECM to check coils I will do that but I did test for spark at the wires. No spark there.
Also I noid tested the injectors and they are not pulsing at all.
Old Apr 21, 2010 | 10:59 AM
glennhl's Avatar
glennhl
Crank sensor?
Old Apr 21, 2010 | 04:52 PM
fc_soldier's Avatar
fc_soldier
looking into it I got the pin out so I will be testing it today.
Old Apr 21, 2010 | 07:18 PM
fc_soldier's Avatar
fc_soldier
Found my problem, I have a broken ground Im working on the fix now.Its somewhere in the harness I need to track it down
Old Apr 21, 2010 | 11:41 PM
fc_soldier's Avatar
fc_soldier
OK even the best are wrong sometimes. It isnt a ground. But I found what I think it is.
I checked the pins on my ecm to my cam sensor. One of the pins instead of the 12 volts is the Low Coolant Level Indicator Signal.
To No Spark
