Cruise Control Problem
Old Apr 22, 2010 | 12:43 AM
joeperez's Avatar
joeperez
4th Gear
Default Cruise Control Problem
Have an inoperative cruise control, 2007 C6. Auto w/ paddle shifter, not Z06. Simply won't engage. Have verified e-brake is off (duh) and fluid level in master cylinder is OK, as noted as a requirement, believe it or not, in owners manual. Any other thoughts?
Old Apr 22, 2010 | 01:10 AM
TR-6060's Avatar
TR-6060
A friend of mine lost two BCMs thus far in his 2007 C6 A6. Dead cruise control was the symptom of both failures.
Old Apr 22, 2010 | 11:56 AM
Hoonose's Avatar
Hoonose
First off disconnect the battery ground for 10 minutes or more then reconnect and let the car reboot. This solves many electric gremlins with these cars.
Old Apr 22, 2010 | 12:38 PM
BadSalad's Avatar
BadSalad
A "mechanic" friend of mine once told me that on some newer cars if the 3rd brake light was not working that the cruise wouldn't either.
He wasn't the most reliable friend (known for BS).
But should be easy enough to check.
Old Apr 22, 2010 | 01:35 PM
Vette_DD's Avatar
Vette_DD
Dealer had to replace the BCM in my 06 A6 coupe when the cruise control quit working.
Old Apr 22, 2010 | 08:43 PM
Bill Dearborn's Avatar
Bill Dearborn
Check to see if the brake lights are on. If the switch is stuck or misadjusted it will keep the cruise from turning on.
Bill
Old Apr 22, 2010 | 09:17 PM
joeperez's Avatar
joeperez
4th Gear
Default Rock Star, You Are
That fixed it. Thanks! Better than a dealer trip, to boot. Pun intended. (Why didn't I think of that???)
Old Apr 22, 2010 | 11:44 PM
Vette_DD's Avatar
Vette_DD
Remember that you'll need to reset the window indexing.
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done.
Old Apr 23, 2010 | 12:33 AM
joeperez's Avatar
joeperez
4th Gear
Thanks, will index in the AM. Appreciate it.
Old Apr 23, 2010 | 07:18 PM
VET4LES's Avatar
VET4LES
Hoonose is the best.
Old Jul 24, 2012 | 05:54 PM
sulmer@aol.com's Avatar
sulmer@aol.com
8th Gear
Default C6 Cruise Control Fix!
Just bought pre owned one owner 2007 convertible with 32,000 miles. Cruise control working fine, then one day did not work.
Disconnecting battery 10 minutes worked! Thanks SO MUCH!
Old Jul 24, 2012 | 06:00 PM
Vette_DD's Avatar
Vette_DD
Please don't revive old threads.
http://forums.corvetteforum.com/foru...s-or-more.html
To Cruise Control Problem
