Hello forum members. How would i know when its time to replace the injectors? Would performance on the car be that different where i could tell? Thanks in advance for all your help
You shouldnt need to change em. Just get them cleaned and they should last the life of the motor. If the coil on one goes bad you will notice a loss in performance.
Use quality fuel and every so often run some Chevron Techron PLUS in a full tank of fuel and you should NEVER have a dirt issue.
If your talking about LARGER injectors to increase HP,,,unless you have increased engine displacement, or a very large cam, ported FAST etc.... the stock injectors should be fine.
Find someone with EFI Live or HP Tuners and see what your injector duty cycle is with full load and at full throttle. If it's above 85%, switching to a larger injector may free up power but, not much. To increase the size of your injectors, you will need to have the PCM tuned to match the larger injectors.
