comp cam swap
Old May 5, 2010 | 12:21 AM
warwolf's Avatar
warwolf
Good call ! I hope he can get a little more out of it.
Old May 5, 2010 | 10:49 PM
warwolf's Avatar
warwolf
432 rwhp 390 ft. lbs. my car rocks at idle.
Old May 6, 2010 | 12:03 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
damn, im good. hope you like it,, throw a fast on there and thats another 25rwhp and 30rwtq!
Old May 6, 2010 | 02:19 AM
PRE-Z06's Avatar
PRE-Z06
dang I was hoping you'd be able to squeeze a little more out of her, must be a stingy dyno...I agree with Carl tho, a ported fast will probably put you close to 460!
Old May 6, 2010 | 09:12 AM
warwolf's Avatar
warwolf
cool i'll do it.....
Old May 6, 2010 | 08:56 PM
warwolf's Avatar
warwolf
Man u guys are good .the tech that did my cam said i would pull 450+ rwhp on a different dyno.
Old May 6, 2010 | 11:52 PM
carlrx7's Avatar
carlrx7
what dyno did you use? can you post the dyno itself?
Old May 7, 2010 | 01:03 PM
warwolf's Avatar
warwolf
it's not a dyno jet. he took off my back tires and hook up.i have a mini lap top it wont let me post a picture.
Old May 7, 2010 | 01:44 PM
ian@thetuningschool's Avatar
0ian@thetuningschool
Former Vendor
I think they use a dynapack dyno. Was it victor tuning your car?
Ian
Old May 7, 2010 | 03:58 PM
warwolf's Avatar
warwolf
yes , is that about right?
Old May 7, 2010 | 09:44 PM
warwolf's Avatar
warwolf
what size fast do i get for my car?
Old May 8, 2010 | 10:41 AM
C7&7's Avatar
C7&7
The new 102mm is the one you need. There is a supporting vendor on the forum selling them fairly cheap. It does not require any modifications to fit. I just did on ein my '05 after a cam install and picked up 19 and 21. You probably will not see the 25-35 hp gains some see with stock heads. Our LS2 heads suck!
Old May 8, 2010 | 10:13 PM
  #33
bunk22's Avatar
bunk22
This is prior to my cam, replaced my ported stock intake with a stock FAST (the older one which I assume they don't make anymore). All dyno's on a dynojet SAE corrected:
Same mods but with the cam in my sig:
Old May 9, 2010 | 12:07 AM
  #34
c6 batmobile's Avatar
c6 batmobile
Originally Posted by SpinMonster
I've been using the 236XFI/236XER 114 and with trick flows its 505-515 depending on the other mods. FAST is mandatory.
This is the cam I plan on using coupled with a ported FAST TF 225's and a small shot of NOS. It should make serious HP. Spin specs some pretty sweet cams and he is extremely knowledgeable.
Old May 9, 2010 | 01:33 AM
  #35
warwolf's Avatar
warwolf
When u install a fast do u have to retune?
