LS2 10.9:1 compression?
Old May 6, 2010 | 06:00 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Default LS2 10.9:1 compression?
I'm curious as to how GM came to 10.9:1 compression on the LS2. LS2 heads are the same 64cc chamber'd heads on the LS6, but the LS6 has a 10.5:1 compression. How did GM get 10.9:1 compression out of the LS2?
Old May 6, 2010 | 07:30 PM
glass slipper's Avatar
glass slipper
More displacement...for a given combustion chamber and all else being equal (head gasket volume, piston deck height, and piston dish/valve relief/dome), increasing engine displacement will cause an increase in compression ratio.
CR = (CV+CCV)/CCV
CR=compression ratio
CV=cylinder volume
CCV=combustion chamber volume
Easy to see when you look at the formula...the top number increases with an increase in displacement while the bottom number stays the same.
PS I left out the head gasket volume, piston deck height, and piston dish/valve relief/dome variables in the CR formula above in the interest of showing the affect of displacement on CR.
Old May 6, 2010 | 08:05 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default Cr calculator
CR = (CV+CCV)/CCV
CV=cylinder volume
I agree with everything you say but on this formula I come up with
10.46 CR for the LS2. With the following assumptions.
1 4.007 BORE
2. 3.622 STROKE
3. .051 COMPRTESSED HEAD GASKET
4. 65 CC CHAMBER VOLUME
5. 0 DOME VOLUME
6. .016 PISTON TO DECK.
7. GASKET 4.060
used this CR CALCULATOR http://www.csgnetwork.com/compcalc.html
Old May 7, 2010 | 07:03 AM
glass slipper
1 4.007 BORE
2. 3.622 STROKE
5. 0 DOME VOLUME
7. GASKET 4.060
Let's review a few of your assumptions...
1. The bore specification is 4.0007"-4.0017".
4. The OP says the chamber volume is 64 cc, which one is correct?
6. You entered the piston deck height as a positive number in the calculator, pistons above the deck have to be entered as a negative number. Having said that, are you sure .016" is the correct number for LS2s. I thought is was more in the range of .005"-.010".
Find the exact numbers for chamber volume and piston deck height along with the correct sign and recalculate. You should be closer to 10.9:1 with the correct entries.
Old May 7, 2010 | 07:32 AM
LSCHLEM's Avatar
LSCHLEM
Thanks for correcting me on that. The DECK HEIGHT is below deck therefore a -.007 gets it close
, Actiually the Chamber volume on the LS2 is 65CC.
Old May 7, 2010 | 01:46 PM
All_Motor_C5LS6
LS1 uses a 66cc chambered and LS6/LS2 share the same 64cc heads.
Old May 7, 2010 | 02:18 PM
LSCHLEM's Avatar
LSCHLEM
Its interesting you mentioned that. In the other thread when I was checking chamber volumes it was really close.
To LS2 10.9:1 compression?
