LS376/480 Help
Old Jun 11, 2010 | 08:12 AM
GTM4ME's Avatar
GTM4ME
Default LS376/480 Help
I am using a new crate LS376/480 in my GTM and need a little help. The car starts right up and idles fine. There is a slight hesitation when pressing the accelerator and if I rev it to about 3000rpm and let off, it will die. I have a OBDII code reader but when I connect it, it tells me there is a link error. As far as I can tell, everything is connected. The engine came with the pedal and ECU so it should all be compatable. Any help would be greatly appreciated.
Mike
Old Jun 11, 2010 | 08:36 AM
NYC6's Avatar
NYC6
Wish I could help you Mike but I dont know. Im sure someone here can give you some tips.
I am curious your engine choice though. Saw it in the GM catalog and thought they looked like a good option. Can you give us some thoughts on it after you get it up and running strong? Thanks. Good luck sorting it out.
Old Jun 11, 2010 | 08:58 AM
NIGHTSTALKER's Avatar
NIGHTSTALKER
Whats a GTM???
Old Jun 11, 2010 | 09:44 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Don't know what you have and how your are tuning and what's the set up.
You may be better off going to the HP Tuners website.
Old Jun 11, 2010 | 10:04 AM
GTM4ME's Avatar
GTM4ME
Originally Posted by NIGHTSTALKER
Whats a GTM???
Designed by Factory Five Racing using a C5 as a donor. Donor parts include upper and lower control arms, brakes, fuel tanks, steering column, radiator and fans, window regulators and motors, mirrors and door handles, wiper motor, a/c compressor and some other small stuff. It's mid-engine using a Porsche transaxle. It is almost 6 inches shorter than a Vette and weighs 2400 lbs.
Old Jun 11, 2010 | 10:08 AM
LostAngel's Avatar
LostAngel
Coming together NICELY!!
Old Jun 11, 2010 | 10:21 AM
tjwong's Avatar
tjwong
Where is the MAF sensor mounted? I am willing to bet that the reason you are having an issue is because the design of that air intake system is causing a MAF signal disturbance at that RPM. Any flow measurement device needs X amount of down and up stream straight run to provide a decent laminar flow to the device.
Old Jun 11, 2010 | 10:25 AM
GTM4ME's Avatar
GTM4ME
I have it located like the instructions say but I will move it too see if that changes anything. BTW, the MAF sensor is in the driver's side of the intake and the passenger side is blocked off at the Y pipe.
Thanks for the suggestion!!
Old Jun 11, 2010 | 04:35 PM
LS1LT1's Avatar
LS1LT1
I like those cars.
Old Jun 13, 2010 | 09:15 PM
tjwong's Avatar
tjwong
Ahh, ok if you are only running one side, then that should work fine, as long as you have good straight run after and before the sensor.
To LS376/480 Help
