*Quick Question Regarding Tires
Old Jun 23, 2010 | 01:41 PM
Dnelson's Avatar
Dnelson
Default *Quick Question Regarding Tires
I just blew a tire and was wondering if a 295 30 19 will fit on my 05 Z51
Thanks,
Sorry for not searching im sure it is on this forum somewhere, trying to use my cell phone to search this forum
Old Jun 23, 2010 | 04:11 PM
Dnelson's Avatar
Dnelson
Thanks,
Anyone?....
Old Jun 23, 2010 | 04:17 PM
hydbyj's Avatar
hydbyj
Default rear tires
[ i just ordered 305/30 19's for my 09 C6, they are the same tires used on the Z06 from what i understand. the tire dealer should have that info before you purchase. jerry
Old Jun 23, 2010 | 04:44 PM
LS1LT1's Avatar
LS1LT1
Yes, while they're not the exact replacement tire size they will work/fit.
Actually the C6 Z06 uses 325-30-19s on the rear.
Old Jun 23, 2010 | 04:48 PM
hydbyj's Avatar
hydbyj
i stand corrected, thanks, jerry
Old Jun 23, 2010 | 05:48 PM
haljensen's Avatar
haljensen
Thanks,
Maybe they'll fit on the wheel but unless you buy the same tire in 255/35/18 at the same time for the front you will have problems with Active Handling and Traction control.
If you change rear diameter you must change front diameter also.
http://www.1010tires.com/TireSizeCalculator.asp
Old Jun 24, 2010 | 01:30 PM
Vito.A's Avatar
Vito.A
I ran 305/30-19 rear and 275/35-18 fronts on my C6 Coupe. No active handling problems. Some other folks have used the same rear and a 265/35-18 front and it works great also.
The 305 rear is a slightly smaller diameter and the speedometer is off about 1 mph. You can correct this with a tune, a hand held Predator tuner, or just not worry about it.
285/35-19 3.9" 13.4" 26.9" 84.4" 751/mi 60MPH 10000mi N/A
305/30-19 3.6" 13.1" 26.2" 82.3" 770/mi 61MPH 10248mi -2.4%
To *Quick Question Regarding Tires
