C6 Power Steering(PS) Pump swap taking PS pump alternator bracket off car
Old 07-20-2014, 06:12 PM
Ahmer
Ahmer's Avatar
Anyone ever remove the pump without actually disconnecting the high pressure hose from the rack and pinion???
As in get the pulley off while the pump is still attached to the rack and pinion.
Old 07-20-2014, 11:48 PM
TTZ06VETTE
TTZ06VETTE's Avatar
Yep...PITA
Old 07-22-2014, 06:55 AM
Ahmer
Ahmer's Avatar
Nice. Will have fun with this today. I still cant pinpoint my leak. My rack and pinion is dry, NO fluid inside either. Initially my SHORT (OLD DESIGN OEM) high pressure hose was soaked, so I thought it was the culprit, Now I am thinking my actual POWER steering pump maybe the issue.
Will replace the pump and see what happens. I hope its not my rack and pinion...
gbslagle (10-21-2015)
Old 11-17-2014, 05:20 AM
Yasei
Yasei's Avatar
Anyone have the GM part number for the new long-style PS hose? Nunber 10 in this pic:
Old 11-17-2014, 07:30 AM
timd38
timd38's Avatar
They don't sell the old one anymore, so if you try to order it you will get the new style one. Plus, you may get a free one because there is a recall.
Old 11-17-2014, 07:33 AM
Yasei
Yasei's Avatar
I know about the differences and recalls. I'm looking for the new part number as I mentioned in my question. All I need is the part number.
Old 11-17-2014, 07:10 PM
05C6GAC
05C6GAC's Avatar
The new one make the install easier as you have more length to play with but it's still APIA. I did mine in the driveway this past weekend, took a little while to figure out how the new line routed, but it seems I finally figured it out. If I was anyone thinking about doing it, I'd change the line and the pump at the same time. I did the pump about a year ago and probably damaged the hose and now the hose was leaking. By the way I did change out to the Turn one pump and would recommend it, by the way pay the extra money for the pulley, it make the install of the bolts easier, still APIA, especially when you figure out you did something wrong and need to undo.
PS. From looking at the bag it looks like the new P/N is 15903240 for the hose. hope this helps
Old 11-18-2014, 02:05 AM
Yasei
Yasei's Avatar
Thanks for the part number. It links to a diagram that has the older hose though, but they'll probably only send out the new ones now.
Old 11-18-2014, 02:59 PM
timd38
timd38's Avatar
$62.00 from the local parts store.
Old 11-18-2014, 07:45 PM
05C6GAC
05C6GAC's Avatar
Sounds like GM change the part and not the P/N again. Someday they will learn???
Quick Reply: C6 Power Steering(PS) Pump swap taking PS pump alternator bracket off car
