Okay so i have an 05' that is in right now for the crank pulley bolt issue. Well the harmonic balancer is on "national backorder" per GM. So i went to LG and picked up thier underdrive pulley to replace it.
The Fix that Gm had for the problem with the 05's is to put that washer (diamond etched or something) in there to help hold it in.
Now i called 2 performance shops and they just say that all you need to use is the bolt that has the red material on the underside of the large washer head and torque it to the right specifications.
The Chevy Dealership wanted to warn me that since this underdrive didn't come with a washer like the OEM part now comes with you may have the same problem.
Does anyone know the story here, especially for 05's, if most people reuse the washer that may come with the new bolt on the inside of the balancer/pulley, or if it is even necessary?
The original bolts were supposed to be defective. The replacment bolt with the red stuff underneath it is supposed to be the replacment. I used that same bolt on my car when I did my cam swap two years ago and havent had a problem with it.
And you did not put a washer (Diamond etched or whatever that 05 service bulitin said) on the inside of the pulley as like an extra.
I am just verifying the pulley and bolt on the outside are all that are needed. I think they are going to put a new seal in but i don't need a washer on the inside of the pulley?
Again all advice is helpful as I will check with LG in the morning, but really would like them to finish with my car tomorrow.
Can someone confirm this is the DEW (diamond embeded washer) everyone talks about with this fix.
If i went with an aftermarket pulley, do i still need this washer??
That washer didn't fit on my SLP/Powerbond pulley so I didn't use it. No issues thus far. When I asked the question I was told it was there to keep oil from leaking. The pulley is a tight press fit and I couldn't see how any oil could get by.
The washer has nothing to do with oil control. It is there to reduce the risk of the damper rotating on the nose of the crankshaft, a known issue. If the rubber part of the washer doesn't fit the damper it can be cut off ad the washer used by itself. If it is put on without the rubber part it needs to be tacked to the damper with super glue to hold it during assembly to keep it aligned.
You can assemble without it but your risk of damper spin on the nose of the crankshaft goes up big time and in worse case you stand a risk of having to replace the crankshaft if it does spin. I wouldn't put one together without it. JMHO!
Well I asked the same qustion a few months back and few folks responded about oil. I didn't buy it and didn't use the washer. However, I DID pin the crank, which is a much better fix than that washer IMO.
Pinning the damper to the crankshaft will help, but I still would not assemble without it, even if it is pinned. The LS9 uses a key between the crank and damper but still uses the diamond washer.
The LS9 is spinning a blower, hence the need for the pin.
You're using an aftermarket balancer, go nekked and torque to spec.
