What is this on my VIS:
Old Jul 7, 2010 | 06:10 PM
beerbarrel's Avatar
beerbarrel
Default What is this on my VIS:
Obtained a VIS on my car and found out why I did not get a recall on my C6 for the roof. It seems it was replcaed in 08 under warranty. Now I do have a question. What is "F2123 carrier assembly rear differential R&R"? I do know what a diff is...my question is do they replace the complete carrier assy and why would they? When I say complete carrier does that include ring and pinion, spider gears? The complete chunk or is is just the carrier for these items? It is a 2006 btw.
Thanks,
Tracy
Old Jul 7, 2010 | 06:36 PM
Epic_C6's Avatar
Epic_C6
Thanks,
Tracy
R&R means remove and replace so I would assume they removed the old one and replaced it with a new one. As to why, you will have to find out what dealership did the warranty work and contact them. They should have a record of the service performed, especially since it is warranty work.
Old Jul 7, 2010 | 07:16 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Thanks,
Tracy
Most likely the previous owner either grenaded it and replaced it under warranty or the dealer did not know that a simple fluid change would fix the chatter in the rear diff so they replaced the entire carries assembly. If you PM me your VIN, I can see if I can dig up anymore info like the part number replaced or if there were any notes in the system from the dealer or rep.
Old Jul 7, 2010 | 08:00 PM
beerbarrel's Avatar
beerbarrel
Yep, good with what R&R meant...I was mainly interested in what was R&R exactly. Is labor code F2123 a catch all for everything or something specific.
Old Jul 7, 2010 | 08:02 PM
beerbarrel's Avatar
beerbarrel
PM sent....thanks!
Old Jul 7, 2010 | 11:13 PM
Epic_C6's Avatar
Epic_C6
F2123 Is a GM code for a specific "labor operation" it means exactly what you said; F2123 - CARRIER ASSEMBLY - REAR DIFFERENTIAL - R&R. That is as specific as it gets with out the actual Work Order from the dealer that did the service work.
Old Jul 7, 2010 | 11:24 PM
beerbarrel's Avatar
beerbarrel
Guess I'll never find out for sure. I have no idea who did the work.
Tracy
To What is this on my VIS:
