Extremely bumpy ride...
Old Jul 19, 2010 | 10:59 AM
ls2kev's Avatar
ls2kev
Default Extremely bumpy ride...
Every little bump I come across on the road shakes my car...
What can I do to reduce this?
Better tires? (if so, which ones??) ... or do I have to go so far and get better shocks?
I feel like my car is going to break apart. But when I go over the same bumps in a 2008 Camry, it's like they don't even exist on the road. Is this one of the disadvantages of a low ride??? (no my car isn't lowered)
Old Jul 19, 2010 | 11:05 AM
TysonJones's Avatar
TysonJones
There are things you can do to kind of improve it but this ride quality is just something you sacrifice for the performance. My new GS actually rides very very good compared to my ls1's. Nothing amazing but plenty good for me, pretty comfortable actually.
Old Jul 19, 2010 | 11:15 AM
RicK T's Avatar
RicK T
The tires are part of it. By most accounts here other tire brands, even in runflat form, are a little softer riding. If you have a Z51, many have reported that switching to Bilstein Sport shocks makes a difference. Going to Koni FSD's, at twice the price of Bilsteins, are even better.
Old Jul 19, 2010 | 11:20 AM
Hoonose's Avatar
Hoonose
Better tires? (if so, which ones??) ... or do I have to go so far and get better shocks? toetap:
Base, Z51 or F55 suspension?
How are your roads?
Tire type, RF or not?
Tire pressure?
My Z51 is fine where I live in Havasu, AZ, but I would never have it if I lived in Flagstaff where the roads are all concrete and broken up from ice and snow.
See if you like the ride better with say 26 pounds in the tires. In fact use a known correct gauge to check the actual numbers vs the DIC.
Next would be taking a drive in a similar C6 with non-RF tires and see what you think.
Old Jul 19, 2010 | 01:06 PM
goatts's Avatar
goatts
Yes. Your car is a compromise. It has a stiff high performance suspension and engine. You can take corners at high speed with little body roll. You can drive your car to the track (and drive on the track) on the weekends and drive to work on week days. Different tires aren't going to help.
Old Jul 19, 2010 | 01:19 PM
LS1LT1's Avatar
LS1LT1
How are your roads?
Tire pressure?
That's what I was going to ask as well.
Tire pressures can make a big difference.
Also, how many miles on the car (shocks going bad maybe?)?
Old Jul 19, 2010 | 01:28 PM
ls2kev's Avatar
ls2kev
How are your roads?
Tire pressure?
The roads in my area are pretty sh!tty, actually... I don't mean to say there are pot holes or missing pavement... but it's like they hired the most retarded people who don't understand the concept of creating a straight/smooth pave job. There are literally bumps in the road.
My tire pressure varies on the temperature... it's in the 30-34 range.
I have the stock run flat tires
My car has around 58000 miles (2007 Base Coupe)
I have no mods on my car that deal with performance or handling.
Old Jul 19, 2010 | 01:40 PM
Hoonose's Avatar
Hoonose
I would first experiment with lower tire pressures.
I used to run 26# when my C5 and C6 tires got older and harder.
If that helps the next step might be non-runflats, if you could live with that.
Old Jul 19, 2010 | 02:44 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Welcome to the world of run flat tires. The very stiff side walls are the main cause of the harsh ride you describe. You posted that you have 58K miles, but how long have you owned it? If you're a new owner & this is your first C6, you're probably just not used to the stiffness of the suspension. Another point with 58K miles is that it might be time for new shocks. My '05 is a weekend driver that I've owned since new & I've only got 25K miles on it. At around 15K miles, I got fed up with the harsh ride from the GY Supercars (Z51 tires) & went to Nitto Invo's. Difference in ride performance is amazing & yes, they're non-runflats, but I carry a plug kit & small air compressor. Just some things to think about....
Old Jul 19, 2010 | 04:16 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I think Dave has hit on many of the topics. But the first to me is, did you ck the tire pressures by hand gauge, or is this DIC reading?
58K miles, are they all on this set of tires (doubtful but possible)?, in which case it may be time to change them--they may be stone-hard?
finally, have you or someone crawled underneath to look at the shocks? they could be leaking. ordinarily I wouldn't expect shocks to go out at that mileage, but it's not impossible.
you might also want to test ride a friend's similarly-equipped Corvette.
Old Jul 19, 2010 | 05:26 PM
goatts's Avatar
goatts
The OP is comparing his ride to that of a Camry. You can't do that. Apples and oranges. Changing to non runflats is not going to make his car ride like a Camry, nothing is. Changing tire pressure will make his tires wear unevenly.
Upgrading shocks to Bilstein or Koni may help a little.
Old Jul 19, 2010 | 05:35 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Chuck the runflats.
Old Jul 19, 2010 | 09:08 PM
turbo2001's Avatar
turbo2001
Default bumps
great idea if you know where the potholes and bumps are avoid that road while in the vette, and when in the camry take the shorter route and drive ***** to the wall through it!!!
Old Jul 20, 2010 | 06:48 AM
ls2kev's Avatar
ls2kev
No potholes... but thanks.
Old Jul 20, 2010 | 10:40 AM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I would agree that you should check the tires cold and put them around 28lbs and see if there is an imporovement, if not start thinking about replacing the tires with practically anything as they will be better than the badyear runcraps.
Old Jul 20, 2010 | 03:30 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
i put Koni FSD shocks and Michelin Pilot Sport PS2's (non runflat tires) and the ride was great (2005 C6 nonZ51). I also had the Z51 sway bars on the car.
Old Jul 20, 2010 | 05:34 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Seems to me if the ride is "extremely bumpy" then something is wrong. I have a stock 06 vert with GY runflats and the ride is fine. I often drive my wife's Toyota, and switching back and forth with the Vette doesn't make me think the Vette rides rough. And this is in Pennsylvania, with the worst roads in the country.
To Extremely bumpy ride...
Old Jul 20, 2010 | 06:32 PM
ytry's Avatar
ytry
Default rough ride
i live in maryland i can take you for a ride in mine if you want i have a 2006 z51 with run flats 54k
Old Jul 21, 2010 | 06:48 AM
ls2kev's Avatar
ls2kev
How close are you to the Hyattsville area?
Old Jul 21, 2010 | 08:39 AM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Check the tunnel plate to see if it is torqued to specs, 8 ft lbs. CF members report a thicker plate will make the car stiffer.
