Oil Change
Old Aug 20, 2010 | 08:00 AM
PUREVOL's Avatar
PUREVOL
Default Oil Change
Need an oil change in my C6. I went to the dealer before for my first one. I know what i'm about to ask is probably obvious but should i go to a "oil change shop" or back to the dealer for this one?
Old Aug 20, 2010 | 09:33 AM
Wayne O's Avatar
Wayne O
CF Senior Member
For many reasons I'd recommend you learn how to change your own oil. If that's not an option, of the two choices I'd pick the dealership.
Old Aug 20, 2010 | 10:48 AM
kmthor00's Avatar
kmthor00
I am not in a position to do it myself so I ALWAYS go to the dealer but be ready to pony up some $$$$.
Old Aug 20, 2010 | 01:46 PM
carpe dm's Avatar
carpe dm
DIY would be best. Too many "Oh, I forgot the plug" stories associated with the oil change shops.
Old Aug 20, 2010 | 03:33 PM
VET4LES's Avatar
VET4LES
DIY. It's the only way to know it's done right. Even the dealers screw up. How many quarts do they use? C5's are different than C6's and not all C6's are the same. The oil jockeys could use different oil than you would, we read where they over fill and under fill. It's not worth it. I do mine in 20 minuets or less and I'm 71. It cost about $35 to DIY.
Old Aug 20, 2010 | 08:20 PM
j_digi454's Avatar
j_digi454
and I'm only 69 and still do it not for the savings but for the knowledge that is done right.
Old Aug 20, 2010 | 08:52 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
as well. I let my old oil drain for hours just to let the old stuff out. I'm way too particular to expect someone else to do something to my satisfaction.
San
Old Aug 20, 2010 | 09:42 PM
VET4LES's Avatar
VET4LES
San
Old Aug 20, 2010 | 10:46 PM
c6 batmobile's Avatar
c6 batmobile
Please for the love of all that is good and holy do it yourself. It is so simple they could teach monkeys to do it. This way it will get done right and there wont be some A-hole driving your car around while you think your oil is getting changed.
Old Aug 21, 2010 | 02:53 PM
TXC6Z51's Avatar
TXC6Z51
Before I had a lift I would take my own oil/filter to the dealer and they would charge about $10 to change it.
Old Aug 21, 2010 | 04:43 PM
JoesC5's Avatar
JoesC5
You mean that in three years, when I'm 71, I'll be able to change my oil in 20 min instead of the hour it takes me now. I knew there was a good reason people got older.
Old Aug 21, 2010 | 05:05 PM
VET4LES's Avatar
VET4LES
Just wait. You will find many other reasons also.
Old Aug 21, 2010 | 06:06 PM
JoesC5's Avatar
JoesC5
My brain/body is conditioned so that it takes a nap every time my body is in the prone position. Doesn't matter if I'm on my bed, my couch or my garage floor, under a car.
Old Aug 21, 2010 | 06:51 PM
VET4LES's Avatar
VET4LES
Old Aug 22, 2010 | 09:21 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
If you decide not to do it yourself find a mechanic you can trust and go to him every time. Make sure you use a good filter and a good synthetic such as Mobil 1. I change the oil myself and can get er done in twenty minutes easily.
Old Aug 22, 2010 | 03:48 PM
blue383's Avatar
blue383
If you don't want to do the change yourself, I recommend the dealer unless you know the oil change shop well enough to trust them to put in the right type & amount of oil, torque the drain plug & filter right, etc. I once heard a story of an oil change shop that put 5 quarts of oil in a Porsche 911 (actual capacity is 10-11 qts). The engine was destroyed by low oil level.
Old Aug 23, 2010 | 05:09 PM
silver ls2's Avatar
silver ls2
Learing to change your oil is easy. Getting under your corvette to appreciate all the undercariage is awinspiring. I spend about 15 minutes just looking at everything.
To Oil Change
Old Aug 23, 2010 | 06:41 PM
timd38's Avatar
timd38
Same
Old Aug 23, 2010 | 07:18 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Back when we had only ordinary cars, I tried several of the big oil change chains and one purely local outfit. All of them were bad beyond belief.
Old Aug 24, 2010 | 09:35 AM
LeMans05C6's Avatar
LeMans05C6
I did my own this weekend. Royal Purple Oil and Filter. Its satisfying to know you did it yourself and yes to know good quality oil is in there and its done right. At least its on me if its wrong not some lazy oil shop guy.
