TPM Learning on DIC?
Old Sep 19, 2010 | 09:36 AM
t.borries's Avatar
t.borries
Default TPM Learning on DIC?
I have the magnetic tool for TPM learning but don't have the sequence for the learning process on the DIC. I've done this on the C5 that I had but forgot the process.
Old Sep 19, 2010 | 12:11 PM
t.borries's Avatar
t.borries
Did a search. Found it.
Old Sep 19, 2010 | 05:54 PM
BEZ06's Avatar
BEZ06
I assume you found a thread that had info about using a tool to trigger the sensors on a 2005-2009 C6.
The C5 used a magnet and the DIC, however the C6 uses an entirely different procedure.
The video below shows how to use a tool that transmits the proper radio frequency to trigger the 2005-2009 sensors. The DIC isn't involved at all in the relearn procedure.
A 2010 or newer C6 uses a different tire pressure sensor that doesn't need a tool, but can be triggered by changing air pressure in the tire.
Good luck!!!
Bob
To TPM Learning on DIC?
