service charging system message
Old Jan 26, 2011 | 11:11 PM
ABQ C6's Avatar
ABQ C6
From: Somewhere you've probably never heard of in New Mexico
St. Jude Donor '11-'13-'14-'15
Default Update
So the service guy calls me and tells me the car won't be ready until tomorrow (it was supposed to be ready yesterday). Apparently they put in the new alternator and guess what, it burned up. So they do some troubleshooting and find the harness from the battery to the starter has a short and the lead to the starter has melted. Kinda like the picture earlier in the thread, although I haven't actually seen my starter. So now I get another new alternator at their expense because the one they installed has a lifetime warranty, a new starter because the lead is melted which the extended warranty covers and the dealer will pick up the deductible because they didn't find the bad harness the first time, and the new harness that I get to pay $200+ for because the extended warranty doesn't cover wiring. I sure hope this fixes the problem. I didn't think it was the alternator in the first place and I told them that but hey they are the experts.
Old Jan 28, 2011 | 09:03 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Please keep us informed and if you can, post some pictures of where the short happened.
Old Jan 28, 2011 | 09:07 AM
ABQ C6's Avatar
ABQ C6
Didn't get the car back yesterday. The parts were supposed to be overnighted but as of 3:30 PM they were not there.
I will ask to at least see the bad parts to take pictures.
Old Jan 28, 2011 | 11:00 AM
dgrant3830's Avatar
dgrant3830
We and you, need to see where exactly the short happened in case its an issue for all of us. Please ask them to show you.
Old Jan 28, 2011 | 04:40 PM
ABQ C6's Avatar
ABQ C6
I got my car back.
Sorry I didn't see the last post until now but I did get a look at the starter they removed and it looked almost exactly like the picture in post #4 of this thread, mine was dirtier. I took pictures but the lighting was bad and you really can't see the damage. The similarity is almost scary. How common is this? I'm not sure where in the harness the short was. I was too siked to get my car back after over a week.
Old Jan 28, 2011 | 06:49 PM
StKnoWhere's Avatar
StKnoWhere
Originally Posted by ABQ C6
I got my car back.
The damage in post 4 is most likely simply a loose connection. This increases the resistance which generates heat. The heat loosens the connection more creating more heat. Repeat and you eventually melt the connection as shown.
Good news is by simply making sure that nut is tight the problem can be avoided.
Old Jan 28, 2011 | 08:43 PM
dgrant3830's Avatar
dgrant3830
Its a shame that this came lose and caused this problem and after seeing a few of these just here in the forum, its starting to look like a TSB issue for GM/Chevrolet or a possible recall due to the fire potential.
Old Jan 28, 2011 | 09:56 PM
ABQ C6's Avatar
ABQ C6
Old Feb 16, 2011 | 06:55 PM
ABQ C6's Avatar
ABQ C6
Default Update
It has been a couple weeks now since my car was fixed and I'm happy to report no problems. Even happier to report that my extended warranty actually did cover the cost of the harness so I received a refund check from the dealer yesterday.
Old Jun 13, 2011 | 10:58 AM
jewels7775's Avatar
jewels7775
1st Gear
Well, my Monday started off awesome! Same EXACT problem as described by ABQ C6. I too, limped into the dealership just as my power steering went out, raidio shut down! Heres the difference in stories.... As I was in the service station getting the car checked in, all of a sudden started over heating and spewing anti-freeze everwhere! My car is dying. Its at the dealership right now and crossing my fingers something not too expensive! Like the idea of a silinoid on the starter vs an alternator or something worse! Ill post what they diagnose!!
Old Jun 13, 2011 | 05:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like you either threw a Main Serpentine belt OR the belt BROKE.
If you threw the belt,,,,,,, The harmonic Damper pulley is most likely TOAST and walked forward or AFT. If thats the case,, break out the credit card and prepare to dish out cash in bundles!!!
Dealer charges an arm and a leg for that repair!! If it were me and I needed a shop to repair that issue, I would find a creditable local shop to repair it.
MAKE SURE that they examine the damper if the belt was thrown.
Old Aug 19, 2011 | 03:31 AM
Cloaked323's Avatar
Cloaked323
Great write up !!
