Warning: LS7 Valve Spring Compressor
Old Oct 5, 2010 | 04:22 PM
charoog96's Avatar
charoog96
Default Warning: LS7 Valve Spring Compressor
I am currently in the middle of a cam swap on my 2008 Z06. I already installed the new cam and the next step is to replace the stock valve springs with the patriot extreme double valve springs. I bought the crane "LS7" valve spring tool from summit racing for the job (PN 99475-1). It was an attractive tool for a number of reasons: (1) It mounts to the head and holds the spring in its compressed position so both hands are free to swap the springs; (2) it does both intake and exhaust springs at once; and (3) (not really important but) it is a handsome tool.
The tool simply does not work for an LS7.
At first I thought the tool was misboxed. The part number on the box was correct but the tool just does not mount to an LS7 head. The instructions that also come with the tool state “NOT FOR LS7” and provides instructions for an LT1 motor. Granted the instructions don’t mean much since a lot of companies provide one set of generic instructions.
The real problem is that the LS7 rocker arm mounts are not flat like an LS3. They are radiused. The tool has a flat bottom. The base of the tool sits so high that the top of the base is higher than the top of the valve spring, making it literally impossible to compress the spring. I called summit and they overnighted another one to me.... and it is the same as the previous tool.
Summit claimed that Crane says it works for an LS7. But if you go to the Crane website, they do not list any tool that they claim to work for an LS7. The 99475-1 part number does not even exist on their website.
LS7 do-it-yourselfers beware: Do not buy this tool.
I just ordered a lingenfelter valve spring compressor. I hope it does the job. The tech assured me that their engine builders have been using it on LS7's but we will see. If it doesn’t work, this is going to cause a serious delay in finishing my build. I was hoping to have the car up and running this weekend.
Aside from sharing my experience, I was just curious if others have had a similar experience with this Crane tool from Summit and what valve spring compressor others have been using?
Old Oct 5, 2010 | 04:42 PM
Unreal's Avatar
Unreal
I did my valve springs Sunday with a "screw ****" type compressor. It went great. Just waiting on the cam sensor harness to show up but everything else is done.
Old Oct 5, 2010 | 06:12 PM
Motorhead-47's Avatar
Motorhead-47
Sell it to an LS3 guy...that part # works great on the LS3. I thought Crane went belly up a while back?
Old Oct 5, 2010 | 06:38 PM
charoog96's Avatar
charoog96
Crane did go belly up, but they are back. I am going to be getting a refund for both compressors that summit sent me. But the entire experience has been very frustrating to say the least.
Unreal - do you have a part number for your compressor?
Old Oct 5, 2010 | 07:01 PM
tjwong's Avatar
tjwong
I built my own based on the original LS1 tool by Crane. It works great but its a one off tool.
Old Oct 5, 2010 | 08:54 PM
69dodgecharger's Avatar
69dodgecharger
That tool works great on LS1-2-3's but ya not so great on the LS7's.
Sorry to hear that summit had is mislabeled
I wish they made a LS7 tool though.
Old Oct 5, 2010 | 10:44 PM
charoog96's Avatar
charoog96
What is wierd is that Jegs also has that PN mislabeled.
Old Oct 6, 2010 | 11:50 AM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
If you look on LS1Tech.com there's a guy who sells a similar tool in that it bolts onto the heads where the rockers go but it only does one spring at a time.
I've used it several times on my LS7 and it's always worked great. I just noticed that you're also in the Bay area (I live in Brentwood) so I could even lend it to you if you want. Send me a PM if you're interested.
Christopher
Old Oct 7, 2010 | 11:39 AM
charoog96's Avatar
charoog96
Christopher
Wow, I really appreciate the offer. I may have to take you up on that if the lingenfelter tool gives me trouble with the offset valves. Sent you a pm.
Old Oct 12, 2010 | 01:53 PM
charoog96's Avatar
charoog96
Well, I was able to use the lingenfelter spring compressor to replace all my valve springs. Although the tool did the job, it was still kind of a pain having to hold it compressed with one hand while trying to insert the tiny locks with the other.
It would have been way easier to have the spring held in the compressed position, snap the locks into place around the valve stem with both hands and slowly release the spring. Tim's tool on ls1tech seems to be the ticket. And at 1/3 the price, well worth it. I will defnitely be picking up one of those for future jobs.
Thanks for all the responses. I hope this thread helps others avoid the wrong tools.
Old Nov 30, 2010 | 03:58 PM
kanthony's Avatar
kanthony
Comp Cams makes a shim for using 1.800" installed height springs on a LS7 (which has an installed height of 1.959"). It's part 4862-16.
Old Nov 30, 2010 | 04:10 PM
ITS STOCK's Avatar
ITS STOCK
I used a valve spring tool for a detroit diesel and it worked great.
Old Jun 5, 2017 | 02:10 AM
Z06Wais's Avatar
Z06Wais
1st Gear
Default Have a broken valve spring...
Hey buddy, I'm new to the forum. Wondering if I'd be able to borrow your valve spring tool. I'm located in fremont.
Had a secondary valve spring go bad on me.
QUOTE=thesubfloor;1575539311]If you look on LS1Tech.com there's a guy who sells a similar tool in that it bolts onto the heads where the rockers go but it only does one spring at a time.
Christopher[/QUOTE]
Old Jun 6, 2017 | 04:10 PM
CMY SIX's Avatar
CMY SIX
S&S bought them, Hot rod Harley motors S&S
Old Jun 7, 2017 | 10:11 AM
96GS#007's Avatar
96GS#007
Christopher
[/QUOTE]
2010 is calling and would like its thread back.
Seriously, either PM the original poster or start a new thread. One that's roughly 7 Years old is dead and gone
To Warning: LS7 Valve Spring Compressor
