vararam install question
Old Oct 17, 2010 | 02:25 PM
truckplay's Avatar
truckplay
Default vararam install question
why does the battery have to be unplugged? what happens if the battery is not unplugged? does the pcm not recalibrate for the extra air injested?
Old Oct 17, 2010 | 02:48 PM
Mike V.'s Avatar
Mike V.
Default The car will 'splode!
No, it's a CYA safety thing. If you look at instructions for virtually any work under the hood, it starts off w/ unplug the battery. I've had mine off & on sveral times from the FAST intake forward w/o doing so. It's just always a good idea from a safety point whenever working on a car but there definately procedures where it not just a good idea it's manditory for your or the vehicles safety. It recalibrates after several drive cycles, but sooner or later it should be retuned. But I will say as these vehicles get more complicated, don't get to lazy to disconnet a battery b/c you don't feel like resetting your clock.
Old Oct 17, 2010 | 03:00 PM
truckplay's Avatar
truckplay
thanks. I was more concerned about the fly by wire system having a problem reseting.
I did notice the the car went through a 1/4 tank of fuel in about 15 minutes.
thanks again
To vararam install question
