My 2010 ZR1 (only 3,000 miles), is having the issue with the drivers window wanting to index up, then down, then up then down, about 6 times then stops. I've tried disconnecting battery & the 5 sec. trick, no solution. If anything, it created different symptoms. At one point my door (Drivers only) would only open manually, and the drivers window was stuck down, then after sitting 8 hours it started working just not indexing properly.
I just got the car and can only assume the battery is original from 2010, but shows a good charge and cranks beautifully. In short, I have dropped it off to the dealer and will know something next week.
Stay tuned !
If it's only one window I would suspect the window regulator electronics are going.
Stay tuned !
Well, It appears it was low voltage from the car not being driven! The battery has yet to fail, but I think it is the original battery, so I will be buying one sooner or later, and I'm keeping the car for a while, so a new battery is on the way!
I just picked up my car from the body shop yeaterday and I noticed the index problem for the drivers side. Came to the forum for advice and by doing the method stated in the post it works..
