wheel studs
Old Dec 14, 2010 | 01:32 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Default wheel studs
im looking for 1/2'' longer wheel studs but cant find any information about what size studs came stock, any help would be appreciated
Old Dec 14, 2010 | 01:53 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Your search is over now!
http://dougrippie.com/?p=839
If you have any questions let me know!
Randy
Old Dec 14, 2010 | 02:03 PM
SinisterC6's Avatar
SinisterC6
Speedy
Randy
sure does m12 x 1.5 sound correct? what length do i need? im looking to purchase in store because i need these by friday when i install my brakes
Old Dec 14, 2010 | 03:00 PM
BEZ06's Avatar
BEZ06
Yep - 12mm x 1.5 threads, and select whatever length you want.
Here's the picture from the DR site that Randy posted up:
You can see the stock stud at the bottom, so pick what ever length you want - just be aware that unless you're using an open-ended racing lug nut or a spacer, your longer lugs may not allow the stock lug nuts to seat properly and hold the wheel on tightly.
I'd recommend a good set of open-end racing lug nuts for use with extended length lugs - something like the ones below:
Bob
Old Dec 14, 2010 | 03:35 PM
SinisterC6's Avatar
SinisterC6
Speedy
thanks guys!
Old Dec 14, 2010 | 04:20 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Where are you at in the world? Normally I can get stuff to people in a hurry due to our central US location. The coasts are about 4 days away, but 3 day select works slick.
Yes 12mm X 1.5 is correct!!!
Randy
Old Dec 14, 2010 | 04:24 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
good info
Old Dec 15, 2010 | 10:05 AM
godzilladude's Avatar
godzilladude
What is the purpose of longer studs for racing? Just to allow spacers, or is there some strength benefit to having longer studs?
Old Dec 15, 2010 | 08:20 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Well there is a few reasons to run aftermarket wheel studs. Some rule books in drag and road racing require a open lug nut with some stud still sticking out. The ARP studs are hardened and can withstand the abuse of racing, multi impact blows, and etc. It really opens the door to use spacers!
Stock and our 1/2 longer studs are made with a OEM like material. Which is good because of the cost and ease of install.
The Black studs shown in the picture are a GM racing stud. They have a extra starting lug to help with speedy tire changes in the pits. Is it needed? Not really for 99.9 cent of people out there.
I hope this answered the question!
Randy
Old Dec 16, 2010 | 11:20 AM
godzilladude
Randy
It does,thank you sir!
To wheel studs
