Will a big block v8 fit into a C4, C5 or C6?
Technology is so advanced from when BBs were all the rage, it's scary. I can do things to my C6 I couldn't dream of with my '70 Chevelle.
I'm not saying don't listen to your friends but only take advice from those with legitimate experience.
also, listen to the SPINMONSTER !!! he is VERY experienced
You may be surprised to know how much of the "new" technology in the LSx came from the BBCs. People here are acting like technology can only be applied to new engines...the BBC has its fair share of R&D going on now. Do not discount anything just because of its roots...hotrodders are known for their innovation.
Oh I'm not saying that at all. However, it appears as if his friends are basing their performance predictions on what it took to make things fast back in the BB era. Granted the basics are still there because a combustion engine still functions basically the same but you no longer need large cubes, giant cams, and crappy driving characteristics to be fast. The LSx platform is a progression of what was learned back then and will only continue to get better, I hope. Of course now just about anything can be done to a BB but back in the '70s the technology wasn't there. I'm the last person to discredit a hotrodder's imagination. Swapping a BB into a C6 simply for the 'WOW' factor or to make an interesting project for yourself is one thing. But to think you need to swap in a BB to make power....?
This is all a moot point as we don't know what kind of racing the OP is going into. Nobody ever said he had to swap in a BBC to make power but if he expects to win in some classes of racing it would certainly be to his advantage.
Let me give you a little hint...the BBC era never ended. Go do some research and then come back to this discussion. In the meantime, I'll leave you with this: If the "technology" in the LSX was so great, you would see them dominating Pro Stock racing...not only are they not dominating, they aren't even in competition.
But thanks for the hint
:o
I was referring to when BBCs were actually put into production vehicles. Perhaps I took the conversation in the wrong direction considering he wants to build a race car. In that case you're correct he has to adhere to the specific class rules. But yes someone did say he should swap in a BBC, his friends. He doesn't want to, which is why he's here for help. A BBC may be to his advantage but then wouldn't picking a different chassis than the Corvette, judging by his quest for 2000hp? I don't need to do any research and rejoin the discussion because I have neither the knowledge, nor the time at the moment, to acquire the knowledge to offer much useful information. I simply made a statement comparing my old Chevelle to my C6.
:o
:o
If he is, the C6 offers nothing to help him. He needs to find a more suitable platform.
:o
:o
The OP may not want to install a BBC but he does want to be competitive. Sounds like he has two conflicting "wants" which I don't think are going to be resolved here. Personally, I believe if he doesn't know enough to figure it out on his own, he needs to forget about doing anything for now and start reading up on engines.
txrancher47 you need to list your specific goals for the car. This will get you the most accurate information from the big brains and help guide you along the right path.
The small bore of the LSX (relative to the BBC) will never have enough room to fit the valves needed to flow at the 10,000 RPMs the BBC engines turn. The long stroke of the 500 in³ LSX will limit its RPM structurally while the much shorter stroke of the BBC allows it too rev to the moon with no worries.
