*** The C6 Ultimate DIY Thread****UPDATED***
Old Dec 10, 2011 | 09:22 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default e85 Monster Conversion for e85
http://forums.corvetteforum.com/c6-t...n-for-e85.html
Old Dec 10, 2011 | 09:23 AM
pewter99's Avatar
pewter99
Default Big 3 Install on C6 w/pics
http://forums.corvetteforum.com/c6-t...-w-24-pix.html
Old Jan 12, 2012 | 03:14 PM
Muchtodesign's Avatar
Muchtodesign
Originally Posted by taken19
A few more steps indeed, but it can be done without discharging the AC. It's a tighs squeeze, but you can leave the A/C condenser in the engine bay.
Hey Taken.... please explain.... no A/C discharging...
Old Jan 12, 2012 | 03:26 PM
taken19's Avatar
taken19
Track Junky
The AC condenser will separate from the radiator. The AC lines have enough slack in then to allow the condenser to stay in the engine bay. Just zip tie the condenser as far forward as you can without getting too tight, the cam will fit this way.
Old Jan 12, 2012 | 05:53 PM
hep100's Avatar
hep100
I had to change my UD pulley due to the factory wobble. I spent a good hour trying with two of us to get this out but there was no way i could. Maybe you had better luck than me! i am doing the Cam swap when the parts arrive so i will try again and see if it will work.
Old Jan 12, 2012 | 05:55 PM
hep100's Avatar
hep100
pretty easy to recharge your AC yourself so i woud suggest save the busted knucles and discharge it. Made life way easier.
Old Jan 16, 2012 | 12:13 AM
Speedforhire's Avatar
Speedforhire
Default Convertible speaker upgrade...........
http://forums.corvetteforum.com/c6-t...post1579747869
Old Jan 30, 2012 | 10:12 AM
pewter99's Avatar
pewter99
Default How to remove the center console/radio bezel in the C6
http://forums.corvetteforum.com/c6-t...l-removal.html
Old Mar 4, 2012 | 02:11 PM
markcz's Avatar
markcz
Default DIY Sub Box Dimensions
If you want to make a sub box and/or amp rack that sits on the ledge behind the seats. Something like this or this, you'll need the dimensions of the hatch area.
The front edge of a stowed roof in a coupe will be 9" behind the shelf lip, at a height of 9" above the carpet.
Old Mar 4, 2012 | 02:22 PM
markcz's Avatar
markcz
Default BCM Plug Pinouts from 2007 service manual
Map of footwell area here
BCM C1
BCM C1/C2
BCM C2/C3
BCM C3/C4
BCM C4 (also includes OBD II port under steering column)
Old Mar 4, 2012 | 02:26 PM
markcz's Avatar
markcz
Default C6 Radio Schematics and Plug Pinouts
http://forums.corvetteforum.com/1569046519-post1.html
Old Mar 24, 2012 | 06:53 AM
pewter99's Avatar
pewter99
Default 2012 Seat Conversion
http://forums.corvetteforum.com/c6-c...s-of-pics.html
Old Mar 24, 2012 | 06:54 AM
  #33
pewter99's Avatar
pewter99
Default Zr1 front end conversion
http://forums.corvetteforum.com/c6-c...onversion.html
Old May 14, 2012 | 09:13 PM
  #34
pewter99's Avatar
pewter99
Default 2005 LS2 to LS3 dry sump DIY
http://forums.corvetteforum.com/c6-t...-sump-diy.html
Old Jul 29, 2012 | 06:36 AM
  #35
pewter99's Avatar
pewter99
Default [Beware: LS3 timing chain tensioner] aka: DIY Oil Pan removal guide
http://forums.corvetteforum.com/c6-t...post1581426896
Old Sep 18, 2012 | 12:04 AM
  #36
Harborbreeze's Avatar
Harborbreeze
2nd Gear
You have mention such useful information. Thank you so much for sharing.
Old May 28, 2013 | 07:44 PM
  #37
meanjoe's Avatar
meanjoe
Default The C6 Ultimate DIY Thread is missing............
There was a DIY ZO6 cam install thread, the link was broken and then it was deleted completely. Anybody know where there's a good one to be had? Looks like I'll be posting one here in the next 4-5 weeks but in the mean time I'd like to see one from somebody else. Almost all tips are good tips, almost.
To *** The C6 Ultimate DIY Thread****UPDATED***
Old Jul 22, 2013 | 03:06 PM
  #38
pewter99's Avatar
pewter99
Default Resetting TPMS using different handheld tools
http://forums.corvetteforum.com/1584471220-post12.html
Old Aug 25, 2013 | 12:28 PM
  #39
4SUMERZ's Avatar
4SUMERZ
Default Installing a LCD monitor on Driver sunvisor
Here's a PDF for the install
File Type: pdf
Old Sep 25, 2013 | 08:17 PM
  #40
2007SeeSix's Avatar
2007SeeSix
I too have been searching for a good DIY C6 cam swap write up. It still eludes me. Anyone have one or a link that works???
