*** The C6 Ultimate DIY Thread****UPDATED***
St. Jude Donor '09 and '13
I just wanted to add a service column lock remedy. My manual 2005 had the column lock bypass installed. About 6 months after, the service column lock message appeared. The column was not locking, and I just had the message on the DIC. The car drove fine. The remedy was to have the BCM reprogrammed at the Chevrolet dealership with the column lock system programmed OUT. There is a option on GM software to edit the column lock system software out. The tech showed me the screen on the computer. It will prevent future column lock problems, even with the bypass. It was one hour labor. It worked perfectly. The bypass will NOT prevent future column lock problems. Only reprogramming will.
Just in case any of you wanted to DIY a dash camera mount with a 3D printer.
https://www.corvetteforum.com/forums...m-install.html
DIY: COUPE REAR & TOP PARTITIONS
https://www.corvetteforum.com/forums...artitions.html
Hi,
I've added a post for replacing & calibration the BPS: https://www.corvetteforum.com/forums...on-sensor.html
HTH
HTH
Another one for adding BlueTooth to an 2008 C6 : https://www.corvetteforum.com/forums...-retrofit.html
