Optima Batteries in a C6?
Old Jan 9, 2011 | 05:16 PM
Mr.Big's Avatar
Mr.Big
I run 2 yellow top Optima batteries in my setup, one in each "cubby hole" in the rear, I do this for the high demand my setup has on the electrical system. I had previous issues with the alternator and electrical system in general because of the high output needed. After these additions I've had zero issues to report...
Old Jan 9, 2011 | 08:26 PM
Street Rat's Avatar
Street Rat
Originally Posted by Gering
I have a red top on my 07 DD. So far so good.
Same here in my 2008. Read about them on the forum and decided I'd give them a try.
Old Jan 9, 2011 | 08:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The OPTIMA is not a gel acid battery. Its a standard lead acid battery with a spiral wound cells. I had one in my 02 ZO6. The first one lasted a few months and completely died. Replacement lasted 5 years before it started to have issues.
I decided to use a standard WALMART battery. It only $65. and all the other walmart batteries that I have in my jeeps last 5-6 years easy.
Unless your mounting them in some weird position, thats the only reason to spend that much extra for a battery.
BC
Old Jan 9, 2011 | 09:32 PM
VET4LES's Avatar
VET4LES
My RED top is a few months shy of four years old and still going strong.
Old Jan 9, 2011 | 11:10 PM
GordyRay's Avatar
GordyRay
VETERAN
Default Red top
I have had a red top now for a year in my C6 Coupe and it has been great. Approximately ~~900 cranking/starting amps and it is impressive.
Used a Red Top in my 911 now for 6 years no problems yet.
This red top also looks cool. Same weight as the Delco too.
I bought it because it has more starting power. For any battery, if you don't drive the car oftern, you must keep a battery tender on it or you will hurt the battery life.
Cheers,
Fuze
Old Jan 9, 2011 | 11:58 PM
Ketchum's Avatar
Ketchum
OPTIMA's are designed to be able to take shock.Like a car flipping over.Baja racing.boat racing and such.Other wise a regular battery is less money and usually longer lasting.
Old Jan 10, 2011 | 07:27 PM
speedraider's Avatar
speedraider
Originally Posted by eboggs_jkvl
Well, short life span? My 5 year old optima on the Camaro disagrees. My current optima on my Corvette seems to be working just fine. I had problems with the original Delco batteries, went to Optima and have NEVER had a problem.
I guess I'm just lucky?
Elmer
you are lucky
Old Jan 11, 2011 | 03:46 AM
keyplyr's Avatar
keyplyr
Red top 2+ years and starts the car every morning. When my OEM Delco died at 5 years, I had to get a battery immediately before I turned the car off. Autozone had only the Red Tops & Yellow Tops matched to the Corvette that day. A very agreeable looking blond offered to drop it in for me. I found myself saying
No green fuzzy stuff around the terminals like my old Delco. It weighs the same as the Delco though. I swap it out for a light weight (6.6 oz) Braille Carbon Fiber battery for the track (as well as other lightening measures.)
Old Jan 11, 2011 | 10:30 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I put a yellow top in m 07 last spring - no problems so far. I also put a red top in my old C5 after the OEM battery leaked acid. I had the red top for three years with no problems.
Old Jan 11, 2011 | 11:54 AM
C6FirstVette's Avatar
C6FirstVette
05 C6...Yellow top and is 6 months old...so no problems as of yet. Will say when I have the C6 sitting for a period of time (longest was two weeks) and I place it on the Ctek unit it takes only about 1 hour to go from red to green status... the OEM battery if left off tender for 3 days would require entire night to go from red to green.
Old Jan 11, 2011 | 12:46 PM
THECRAIGMEISTER's Avatar
THECRAIGMEISTER
I have a red top in my C6 that I just replaced after 2 years. It was at a shop being worked on for the last year and I am sure they didn't shift to reverse or start it often enough so it was totally dead. I removed it and hauled it up to Sam's Club and exchanged it for a new one and came home and reinstalled it. Now I am warrantied for another 3 years with full replacement. It may not be an issue on a C6 but what I like about them is the instant delivery of full capacity if needed. Example. I had a Die Hard Gold in my Explorer years ago with a very powerful stereo system. When the bass would hit my headlights would dim and almost turn off. I replaced the alternator with a high output alternator and installed a big capacitor. Still happened. I was told to try an Optima so I did and it could recycle its power quick enough that it wouldn't dim the lights. I have an aux fuel system and will be adding meth injection soon and would probably not have an issue with a quality regular battery for half the price but my Optima was $139 at Sams with a 3yr replacement warranty and it has worked well. I don't think they or any battery takes to being drained down to low voltage or dead. Just my thoughts.
Old Jan 11, 2011 | 03:37 PM
Vito.A's Avatar
Vito.A
I am in the other camp.
I have never had good luck with Interstate batteries and had very good luck with Optima batteries.
I just installed an Optima Red Top 35 in my Z06. It saves 5# over the OEM battery and fits well, although I had to use a different retaining bracket.
I searched online and Advance Auto Parts had a 20% off coupon and they delivered it to my door for $140.
Old Jan 11, 2011 | 09:02 PM
  #33
JoesC5's Avatar
JoesC5
According to Optima's website regarding their warranty, they have a three year free replacement guarantee. If the battery fails before the three years is up, they will replace the battery, free of charge, but the warranty on the replacement battery is what ever remains of the original warrant. If the original Optima goes south in 18 months, they will replace it, but you will only have 18 months of warranty on the replacement battery.
AutoZone warrants their batteries for 8 years. Three years free replacement and pro-rated for eight years. That's five years more warranty then an Optima.
Old Jan 11, 2011 | 09:12 PM
  #34
saplumr's Avatar
saplumr
Same with most replacement warranty issue items. If you have something warranted for 5 years and it is replaced in 4 years 363 days...you have 2 days warranty remaining.
Old Jan 11, 2011 | 09:16 PM
  #35
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% CORRECT!!!! The OPTIMA battery is NO, NADA, ZERO better than any other standard battery in the VOLTAGE/CURRENT OUTPUT rating. My bet is,, IF,, you installed ANY brand NEW battery with the proper rating in your C5, it would have provided the SAME improvement!
Hell, it could have been dirty / improperly attached battery cables for that matter.
The OPTIMA battery is NOT MAGIC! Its a standard lead acid battery... PERIOD!!
Sure,, it has spiral wound cells and a better sealing system. Some people are being duped into purchasing them because there SO MUCH BETTER than the standard battery. it just is not true.
Its a good battery but the price of it out weighs the benefit. If I had a vehicle that needed the battery mounted in a unique (other than vertical) position, I would recommend it hands down. For a C5 corvette, that just isn't the case.
BC
Old Jan 11, 2011 | 10:44 PM
  #36
01vetter's Avatar
01vetter
Default Optima is an AGM battery
BC
You are miss-informed. Optima batteries are AGM batteries (absorption gas matrix). There is a significant difference.
AGM spiral wound batteries do not leak and are more vibration proof. Normal AGM batteries (Red top) do NOT like to be deep discharged. They are designed for daily drivers. So if you let them sit you can discharge the battery beyond the recovery point. Use a battery maintainer and it should last a long time. Otherwise get the more expensive yellow top.
Old Jan 12, 2011 | 01:48 PM
  #37
speedwaywhite's Avatar
speedwaywhite
I have been buying'pre-owned' optima's from a local Interstate Battery distributor for half the money of new, the majority of optima's that are warranted are just dead, they charge them up and they are good to go. I have had two that were turned in for adjustment (one red & one yellow) that were a couple years old, all they needed was to be charged up properly. I now have 3 more years on them with no issues. If you use a tender go red, no tender go yellow. If your optima gets deeply discharged you will have to put another battery in series between the optima and the charger to charge it. I think there may be something about this procedure on Optima or Interstate's web site.
To Optima Batteries in a C6?
Old Jan 12, 2011 | 02:44 PM
  #38
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Personally, I wouldn't run an Optima unless I had a real pressing need for it - odd mounting location, extreme shock or vibration, etc. I do have an Optima in one of my Vettes but I won't be buying another when this one dies. The price to benefit is just not there. They are OK for a DD but I would never put one in a rarely driven car.
Old Jan 12, 2011 | 03:42 PM
  #39
ronkellogg's Avatar
ronkellogg
I replaced the original 4 year old battery with no problems (only because of age and I was getting ready to take a long trip) on my 05 with a Optima yellow top. It lasted 8 months. I "always" use a battery tender when the car isn't driven for more than two days.
Old Jan 12, 2011 | 05:32 PM
  #40
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
No beating up on you, but it that a typo? Should the word be "glass"?
