Optima Batteries in a C6?
Elmer
Yeah, I read that on the internet. I'm down in Little Torch Key right now! Hell, it got down to 51 last night! Would you mind keeping that cold crap on the other side of the state line?
Usually, the Delco oem batteries are good enough for me. But, I felt the Z06 desired bettery. Hope I don't end up regretin this decission.
Anyhoo, after reading thru the thread here. I probably should've opted for the yellow top instead of the red. We'll see....
Anyone got any experience w/ a 'solar' trickle chargers?
Thanks in advance,
Don
I have a high compression engine, and a high lift cam in my 02 Z and even wth a weak, old battey, it cranks fine.
BC
That will allow the car to sit 30+ days and NOT have any cold cranking issues (if the battery draw does not exceed the designed 20ma draw). I have actually had mine sit 45 days and it started with out any issues.
BC
Our batteries have very low internal resistance, which allows them to discharge and recharge very rapidly. It also allows them to operate well beyond their rated specifications. Vehicles that have significant parasitic draws and those that sit for extended periods of time with the battery connected and no battery maintenance can deeply-discharge our batteries.
YLOFEVR is absolutely correct about long periods of non-use and non-maintenance being very hard on all batteries, especially those in Corvettes. As this poster indicated, even Corvette engineers have conceded the parasitic draw on many newer Corvettes can be significant, making a quality battery tender or maintainer an excellent investment for any Corvette owner.
Elmer Boggs, good to see you're still active and I'm glad to hear your Optimas are performing well for you, as well as carlrx7, YLOFEVR, timd38, JoesC5, jpee, Gering, Boomer111, got2hav1, chevybob, Tally Ho, saplumr, Mr. Big, Street Rat, VET4LES, GordyRay, keyplyr, vettecop1125, C6FirstVette, THECRAIGMEISTER, Vito.A, speedwaywhite, JohnDS, and VALS3.
speedwaywhite is correct- many of the “bad” batteries returned to us are just deeply-discharged and as he has found out, they do work fine, when properly recharged.
Since several folks have mentioned the “g” word, I should clarify that our batteries are lead-acid batteries in a spiral cell AGM (absorbed glass mat) design. They can be treated and charged just like regular lead-acid batteries, but “gel” and “gel/AGM” charger settings should be avoided, as our batteries are not gel batteries. Those settings may not fully-charge an Optima and could damage it over time.
THECRAIGMEISTER, when your lights dim when you have a bass hit, that indicates that your alternator is not providing enough electricity at that moment and your stereo is being powered off your battery. A larger alternator and Big 3 upgrade are great modifications for such applications and we recommend batteries designed for deep-cycle use, such as our YellowTops. RedTops offer plenty of cranking amps and are great starting batteries, but they are not designed or warrantied for deep-cycle applications, including vehicles with large, aftermarket stereo systems. JoesC5 is correct regarding our free replacement warranty- it does not “reset” every time a battery is returned under warranty.
Don, the best battery maintainers are microprocessor-controlled. Some less expensive solar chargers do not have proper voltage regulation and can overcharge a battery if left unattended. If anyone has any questions about our batteries, I'll do my best to answer them.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.facebook.com/optimabatteries
